Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Theses, Journals and Papers Request [REQUEST] ASCE Journal/Proceedings
[Request] ASCE Journal/Proceedings
 Vladimir
Ukraine
User ID: 19969
Threads: 42
Likes: 417 in 60 posts
Given Likes: 173
08-18-2010, 06:05 PM (This post was last modified: 05-14-2012, 08:23 AM by mybest.)
I need these papers. Please!
Strength and Stiffness of Conventional Bridging Systems for Cold-Formed Cee Studs
J. Struct. Engrg. Volume 132, Issue 4, pp. 550-557 (April 2006)
Perry S. Green, Thomas Sputo, Viswanath Urala
Distortional Buckling Tests on Cold-Formed Steel Beams
J. Struct. Engrg. Volume 132, Issue 4, pp. 515-528 (April 2006)
Cheng Yu and Benjamin W. Schafer
Plastic and Lateral-Torsional Buckling Behavior of Single Cold-Formed Channels Connected Back-to-Back
J. Struct. Engrg. Volume 132, Issue 8, pp. 1223-1233 (August 2006)
M. Dundu and A. R. Kemp
Distortional Buckling of Cold-Formed Steel Members
J. Struct. Engrg. Volume 132, Issue 4, pp. 636-639 (April 2006)
Gustavo Monteiro de Barros Chodraui, Jorge Munaiar Neto, Roberto Martins Gonçalves, and Maximiliano Malite
Thanks!
[-] The following 6 users Like Vladimir's post:6 users Like Vladimir's post
  • sasan7351, mishanya, fer962933, yly8, warbeast, yamacdere
 Badis
Senior Member
User ID: 16671
Threads: 55
Likes: 2,308 in 169 posts
Given Likes: 221
08-19-2010, 04:09 AM
[-] The following 10 users Like Badis's post:10 users Like Badis's post
  • kowheng, Vladimir, Grunf, concreteok, Dell_Brett, yucapareja, fer962933, yly8, warbeast, Irsyad_Civiliano06
 Vladimir
Ukraine
User ID: 19969
Threads: 42
Given Likes: 173
08-24-2010, 12:50 PM
Thanks to RafikCGS!
Please, help me with new papers:
Finite-Element Simulation and Design of Cold-Formed Steel Channels Subjected to Web Crippling
J. Struct. Engrg. Volume 132, Issue 12, pp. 1967-1975 (December 2006)
Wei-Xin Ren, Sheng-En Fang, and Ben Young
Strength and Behavior of Cold-Formed Steel Z-Sections Subjected to Major Axis Bending
J. Struct. Engrg. Volume 132, Issue 10, pp. 1632-1640 (October 2006)
Ngoc T. B. Nguyen, Tat Ching Fung, and Ben Young
Experimental Capacity Assessment of Cold-Formed Boxed Stud and C Stud Wall Systems Used in Australian Residential Construction
J. Struct. Engrg. Volume 132, Issue 4, pp. 631-635 (April 2006)
Maria M. Pham, Julie E. Mills, and Yan Zhuge
Behavior of Complex Hat Shapes Used as Truss Chord Members
J. Struct. Engrg. Volume 132, Issue 4, pp. 624-630 (April 2006)
Nuthaporn Nuttayasakul and W. Samuel Easterling
Thanks
[-] The following 3 users Like Vladimir's post:3 users Like Vladimir's post
  • yly8, fer962933, warbeast
 masoud_123
User ID: 26084
Threads: 1
Likes: 19 in 1 posts
Given Likes: 8
08-24-2010, 01:05 PM (This post was last modified: 08-24-2010, 01:10 PM by Grunf.)
Hi
I need this paper:
Coupled Foundation-Superstructure Analysis and Influence of Building Stiffness on Foundation Response
[-] The following 4 users Like masoud_123's post:4 users Like masoud_123's post
  • yly8, sodapas, fer962933, warbeast
 Badis
Senior Member
User ID: 16671
Threads: 55
Given Likes: 221
08-24-2010, 02:54 PM
to Vladimir
[-] The following 11 users Like Badis's post:11 users Like Badis's post
  • Grunf, Vladimir, jcbv, Dell_Brett, concreteok, yucapareja, fer962933, yanburak, yly8, harini, warbeast
 Vladimir
Ukraine
User ID: 19969
Threads: 42
Given Likes: 173
08-29-2010, 06:15 PM
Million tnx to RafikCGS!
I need this papers:
Design of Cold-Formed Steel Channel Columns with Complex Edge Stiffeners by Direct Strength Method
J. Struct. Engrg. Volume 130, Issue 11, pp. 1756-1763 (November 2004)
Ben Young and Jintang Yan
Finite Element Idealization of a Cold-Formed Steel Portal Frame
J. Struct. Engrg. Volume 130, Issue 1, pp. 78-94 (January 2004)
James B. P. Lim and David A. Nethercot
Design Expressions Based on a Finite Element Model of a Stiffened Cold-Formed Steel C-Section
J. Struct. Engrg. Volume 130, Issue 5, pp. 708-714 (May 2004)
Steven R. Fox and G. Wayne Brodland
Self-Drilling Screw Joints for Cold-Formed Channel Portal Frames
J. Struct. Engrg. Volume 130, Issue 11, pp. 1799-1806 (November 2004)
Julie Mills and Roger LaBoube
Thanks, Vladimir.
 Badis
Senior Member
User ID: 16671
Threads: 55
Given Likes: 221
08-31-2010, 08:52 AM
Please find your request
[-] The following 13 users Like Badis's post:13 users Like Badis's post
  • Dell_Brett, Grunf, peixoto, pousin, Vladimir, jcbv, concreteok, yucapareja, yanburak, yly8, fer962933, warbeast, Irsyad_Civiliano06
 yanburak
User ID: 27551
Threads: 93
Likes: 821 in 94 posts
Given Likes: 421
08-31-2010, 09:52 PM
Please help me to download these papers:
1. Modification of Behavior of Double-Layer Grids: Overview
J. Struct. Engrg. Volume 115, Issue 5, pp. 1021-1037 (May 1989)
Issue Date: May 1989
2. 2. Effective Length Spectra for Cross Bracings
J. Struct. Engrg. Volume 115, Issue 12, pp. 3112-3122 (December 1989)
Issue Date: December 1989
3. Double-Layer Grids: Review of Static and Thermal Analysis Methods
J. Struct. Engrg. Volume 122, Issue 8, pp. 873-881 (August 1996)
Issue Date: August 1996
[-] The following 3 users Like yanburak's post:3 users Like yanburak's post
 Badis
Senior Member
User ID: 16671
Threads: 55
Given Likes: 221
09-03-2010, 06:35 AM
to yanburak
[/quote]
[-] The following 8 users Like Badis's post:8 users Like Badis's post
  • Grunf, Vladimir, Dell_Brett, yanburak, robertsas, yucapareja, fer962933, warbeast
 Vladimir
Ukraine
User ID: 19969
Threads: 42
Given Likes: 173
#10
09-07-2010, 02:47 PM
Hi,
I need this papers:
Local Buckling Tests on Cold-Formed Steel Beams
J. Struct. Engrg. Volume 129, Issue 12, pp. 1596-1606 (December 2003)
Compression Tests of Channels with Inclined Simple Edge Stiffeners
J. Struct. Engrg. Volume 129, Issue 10, pp. 1403-1411 (October 2003)
Ben Young and Gregory J. Hancock
Cold-Formed Steel Channels Subjected to Concentrated Bearing Load
J. Struct. Engrg. Volume 129, Issue 8, pp. 1003-1010 (August 2003)
Bending Behavior of Composite Girders with Cold Formed Steel U Section
J. Struct. Engrg. Volume 128, Issue 9, pp. 1169-1176 (September 2002)
Shun-ichi Nakamura
Thanks
  • robertsas, fer962933, warbeast, duazo2009, Dell_Brett, ssobhan
Pages (72): 1 2 3 4 5 6 7 8 9 10 … 72 Next »
  [REQUEST] ASCE Journal of Structural Engineering Vol. 132 (2006) mistahpablo 1 2,056 03-31-2017, 04:44 AM
Last Post: pezhmankhan
  [REQUEST] ASCE Journal of the Soil Mechanics and Foundation miquan 9 5,570 12-22-2014, 08:28 PM
Last Post: f_slikken
