Civil Engineering Association eBooks Water & Hydraulic Engineering Groundwater Resources Evaluation, Augmentation, Contamination Modeling and Management
 ska51
User ID: 11535
Threads: 382
Likes: 9,406 in 1,251 posts
Given Likes: 4017
06-19-2010, 12:55 AM (This post was last modified: 06-19-2010, 09:58 AM by Grunf.)
Groundwater (Resource Evaluation, Augmentation, Contamination, Restoration, Modeling and Management)
[Image: 93887047301993090378.jpg]
Groundwater
Edited by: M. Thangarajan
Publishers: Springer (2007)
Pages: 362 (PDF)
ISBN 9781402057281 (HB)
ISBN 9781402057298 (e-book)
The demand for water resources is increasing day by day due to ever increasing population, mostly from developing countries. This has resulted in abstracting more water from the subsurface stratum and forcing the water managers to manage the limited groundwater resources in a more scientific way, which in turn needs a more sophisticated way of assessing the underground resource and manage it optimally. There is an urgent need to locate high yielding oreholes in the hard rock region by using geophysical methods. Electrical imaging technique in conjunction with remote sensing and geographical information system (GIS) technique has proved to be a potential tool for the purpose.
Hydrodynamics of fractured aquifer system in hard rock region is not yet fully understood. The understanding of the groundwater pollution migration in porous and fractured aquifer system and the seawater intrusion in the coastal aquifer has to be improved further. Various aspects of groundwater modeling and in particular issues related to model calibration, validation and prediction has to be understood in much better way. One should integrate all the above issues for effective understanding of the assessment and management of groundwater resources.
Groundwater management needs assessment, which in turn needs a model. A model needs a set of mathematical equations to describe the system. The equations have to be solved through a set of characteristic parameters, initial and boundary conditions of the aquifer system, which in turn have to be obtained through field investigations. Field investigations need a set of procedures, which in turn needs guidelines to carry out field investigations. This book may provide the needed guidelines and answers for all the above.
The aim of the book is to provide theoretical background on the application of remote sensing and GIS techniques in the delineation of subsurface resources as described in Chapter 1. Chapter 2 discusses the principles of electrical resistivity and imaging (tomography) techniques in the identification of potential boreholes in hard rock region. Principles of pumping test analysis and interpretation of data to evolve aquifer parameters transmissivity ‘T’ and storativity ‘S’ through numerical technique have been brought out in Chapter 3. Basic principles and the application of theory of regionalized variables (Geostatistics-Kriging) for the interpolation of sparse hydro-geological data and its estimation error have been stressed in Chapter 4. Augmentation of groundwater resources through aquifer storage and recovery (ASR) along with the quality problem due to reaction of rocks and injection fluid is dealt in Chapter 5. Chapter 6 deals with the environmental problem. The sources and the process of fluoride and arsenic contamination have been brought out clearly in this article. Chapter 7 deals with the characterization of fracture properties in hard rock areas through hydrogeological investigation at different scales. Amethodology was evolved to delineate the vertical distribution of conductivefracture zones and their permeability through flowmeter vertical profiles during fluid injection and evolving the spatial distribution of permeability by making use of slug test data. The above methodology was tested in Maheswaram watershed, a hard rock region in Andhra Pradesh (India). Groundwater flow and mass transport modeling play a major role in the assessment and management of groundwater resources. Modeling principles and various types of models, which are in vogue for various applications are presented in Chapter 8. An exclusive chapter on the model calibration and issues related to validation, sensitivity analysis, post-audit, uncertainty evaluation and assessment of prediction data needs is also presented.
Groundwater development and management of coastal and island aquifers through field investigations and mathematical modeling is brought out in Chapter 10. Basic principles of SUTRA (USGS) finite element model are also highlighted. The management of groundwater resources through community participation approach and some aspects of remedial
measures of contaminated aquifer may provide some insight to the groundwater professionals, which form the Chapter 11.
"Downstream is Weaker"
[-] The following 10 users Like ska51's post:10 users Like ska51's post
  â€¢ shaqee, kowheng, Raktim, oanm2000, toa011, Grunf, guiu15, Nilupa, kaci, lisine
 ska51
User ID: 11535
Threads: 382
Given Likes: 4017
08-17-2010, 08:35 PM
2 More Links:
[-] The following 6 users Like ska51's post:6 users Like ska51's post
  â€¢ Bale, Grunf, Nilupa, malc, oanm2000, kaci
 ska51
User ID: 11535
Threads: 382
Given Likes: 4017
02-10-2011, 08:20 AM
[-] The following 4 users Like ska51's post:4 users Like ska51's post
  â€¢ kowheng, malc, oanm2000, usman
 ska51
User ID: 11535
Threads: 382
Given Likes: 4017
09-23-2013, 01:57 PM
[-] The following 1 user Likes ska51's post:1 user Likes ska51's post
  â€¢ Dell_Brett
  Applied Groundwater Modeling: Simulation of Flow and Advective Transport ska51 1 2,515 11-23-2016, 11:33 AM
Last Post: ska51
  Groundwater Modeling by the Finite Element Method lisine 4 3,137 02-11-2016, 06:20 AM
Last Post: ska51
  Groundwater Geophysics: A Tool for Hydrogeology By Groundwater Geophysics abudabeeja 4 3,819 08-26-2014, 05:53 PM
Last Post: r3be1
  Sustaining Groundwater Resources: A Critical Element in the Global Water Crisis ska51 1 2,309 08-20-2014, 04:24 PM
Last Post: r3be1
  Water Resources and Water Management ska51 2 2,653 05-04-2013, 05:36 AM
Last Post: pezhmankhan
  Gravitational Systems of Groundwater Flow: Theory, Evaluation, Utilization abudabeeja 4 3,439 02-18-2013, 05:43 AM
  Water Resources Planning and Management ska51 3 3,107 01-21-2013, 05:27 AM
Last Post: shadabg
