Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Share your Staad Knowlegde
 verongskey
Russian Federation
User ID: 46
Threads: 39
Likes: 1,792 in 133 posts
Given Likes: 300
#41
05-04-2010, 02:07 PM
Sorry for the incomplete info... Draw a semi-circle or arc in Autocad, divide it into small segment (Use DIV command). Then, enable node object snapping. You can delete the circle (real circle in this case) afterwards. Draw lines in between nodes one by one, until you create a circular pattern that looks like a circle but actually it is just a set of small successive segments of line, and that will be your curved member.
[-] The following 2 users Like verongskey's post:2 users Like verongskey's post
  • rvkumar361, Dell_Brett
 rvkumar361
Junior Member
User ID: 5320
Threads: 2
Likes: 10 in 2 posts
Given Likes: 122
#42
05-04-2010, 04:58 PM
thank u verongskey
till i have a doubt that curved beam have no BM but when we divide it into small segments and draw line in between nodes it look likes as a fixed beam and it have BM.
thanks in advance
 engr1900
User ID: 4169
Threads: 31
Likes: 251 in 53 posts
Given Likes: 1176
#43
05-04-2010, 06:19 PM
(05-03-2010, 08:33 PM)rvkumar361 Wrote: hi,
can any one help me
how to analyze the curved beams and how to design the curved beams using staad
please help me please
Hy
You can refer Staadpro Technical Reference 5.20.8 Curved Member Specification, it may help you or solve your problem
byee
 verongskey
Russian Federation
User ID: 46
Threads: 39
Given Likes: 300
#44
05-04-2010, 08:29 PM
(05-04-2010, 04:58 PM)rvkumar361 Wrote: thank u verongskey
thanks in advance
I don't know exactly what you mean. I will just guess. Curve beam is also a flexural member (w/ torsion) so it has to have BM when subjected to loadings.
[-] The following 1 user Likes verongskey's post:1 user Likes verongskey's post
  • rvkumar361
 rvkumar361
Junior Member
User ID: 5320
Threads: 2
Given Likes: 122
#45
05-10-2010, 01:42 PM
hi verongskey,
please upload one rcc staad model with all member properties and loading for me,
i am learning staad pro individually so i have so many doubts regarding staad pro
once again please upload for me
thanks in advance
 jigarcivil
User ID: 24747
Threads: 4
Likes: 18 in 3 posts
Given Likes: 37
#46
08-08-2010, 01:58 PM
Can i import IFC format of the revit structure model in STAAD pro ?
 CivilEng.
Newbie
User ID: 25784
Threads: 1
Likes: 5 in 3 posts
Given Likes: 11
#47
08-08-2010, 03:02 PM
Hello civil engineers,
More and more I read that many people used STAAD for analyzing their models then used some kind of spreadsheets to design. Why is that? What’s wrong with STAAD design?
[-] The following 2 users Like CivilEng.'s post:2 users Like CivilEng.'s post
  • Ahmed2010, Library
 RAULVB
User ID: 19483
Threads: 1
Likes: 16 in 5 posts
Given Likes: 20
#48
08-09-2010, 09:06 AM
(10-03-2009, 07:39 AM)engr1900 Wrote: Hy
before analyzing it is recommended to check your model, like supports, multiple structures, dimensions.........etc etc
plz share more about staadpro
byeeee
Another Reminder in STAAD Pro
Before you start analysis command you check your model by going to "Tools" Command there you can check your model for any duplicates such as Nodes, Members, structures etc.
 alcalan57
Junior Member
User ID: 3385
Threads: 3
Likes: 27 in 5 posts
Given Likes: 93
#49
09-03-2010, 05:22 AM (This post was last modified: 09-03-2010, 05:27 AM by alcalan57.)
thanks in advance
a curved beam indeed has bm. in fact codes like aashto has special notes in bm acting in arcs
and if you model in very small lines (beams) its the best way as it was say before by verongskey
just remember that the best analysis and design software is as good as the bad engineer using it.
i have face a lot of problems with people that things that using a program and using the results dropped by the software is very easy. but also if you do a mistake in the input the results are going to be very very bad. worst than handmade calculations.
so when using software like staad mus have idea of the results.
 rachid1968
Junior Member
User ID: 16959
Threads: 3
Likes: 0 in 0 posts
Given Likes: 0
#50
09-15-2010, 07:06 AM (This post was last modified: 09-15-2010, 07:10 AM by rachid1968.)
I advise you to avoid using the software staadpro for dynamic studies of the works, since I'm using Staad 97, my advice is to focus to master ETAB, SAP2000.
I dare not say that STAADPRO is a bad tool, but its offer with respect to the dynamic study is incomparable with the options of SAP2000 AND Etabs .
if you find the program options OF ETABS, you will automatically decide the declaration of divorce against the STAADV8i BENTLEY.
Pages (5): « Previous 1 2 3 4 5
