Civil Engineering Association Software Software Product Bentley Products Bentley LEAP PC-HELP 02.01.02 (Trial)
Threads: 1,118
07-29-2010, 02:09 PM
PC-Help is a Windows-based software program for the design and analysis of connections used primarily in the precast/prestressed industry. The program follows the PCI Design Handbook and addresses the following areas:
Welded Headed Studs
Weld Groups
Bearing Pads
Connection Angles
Shear Friction
Bearing on Plain Concrete
Reinforced Concrete Bearing
Column Base Plates
Concrete Brackets or Corbels
Dapped End Connections
Beam Ledges
Hanger Connections (Cazaly and Loov)
Steel Converter
Trial
[Image: 50180170941562615341.gif]
[-] The following 9 users Like BennyP's post:9 users Like BennyP's post
  β€’ kowheng, mulham lee, mowafi3m, jjmtz, oanm2000, murugeshwaran, ALSKERT, spat, bigone
  Bentley LEAP Bridge V8i SS7 14.00.00.19 rami1976 0 5,521 03-24-2016, 05:10 AM
  Bentley LEAP CONSPLICE V8i SS2 01.03.00.03 rami1976 0 6,053 12-13-2015, 08:13 PM
  Bentley LEAP Bridge Steel V8i SS2 01.02.00.01 PinkPant 0 5,475 08-19-2015, 10:06 AM
Last Post: PinkPant
  Bentley PondPack 08.11.01.54 V8i (30 days trial and renew) BennyP 4 13,948 02-15-2015, 12:06 AM
Last Post: fayezkazi
  Bentley Staad Pro v8 (SELECTseries 4) 20.07.09.31 (15 days trial) BennyP 4 15,981 09-09-2013, 05:23 AM
Last Post: pezhmankhan
  Bentley GeoStructural Analysis 16.0 (trial) BennyP 2 8,659 08-08-2013, 11:52 AM
Last Post: 3fan
  Bentley Watercad V8i (SELECTseries 2) 08.11.02.31 (Trial) BennyP 2 10,557 04-20-2013, 07:47 PM
Last Post: jokerβ„’
