Civil Engineering Association Software Software Product Bentley Products Bentley LEAP Bridge Suite v8i (SELECT series 1) 09.00.03.02 (Trial)
Threads: 1,118
07-28-2010, 03:01 PM (This post was last modified: 07-29-2010, 06:24 AM by BennyP.)
Bentley LEAPยฎ Bridge is a fully integrated AASHTO LRFD and LFD (Standard) bridge Geometry, Substructure, and Superstructure analysis, design and rating software for Precast and Cast-in-Place (CIP) post-tensioned or reinforced concrete box girder or slab bridges built on false work.
The LEAP Bridge software program is used to define and manage the bridge geometry, design, analysis and rating for the entire bridge. It allows users to access LEAP component design programs to design various components of the bridge, such as girder and pier elements. It can also be used to define the bridge geometry detail, and perform geometric checks via GEOMATH. The component design programs that can be accessed via LEAP Bridge are:
GEOMATH:
Bridge Geometry Definition and Layout
CONSPAN:
Precast Bridge Superstructure Definition, Analysis, Design and Rating
CONBOX:
Cast-in-Place Reinforced and Post-Tensioned Superstructure Analysis, Design and Rating for Slab and Box Girder bridges
RC-PIER:
Concrete Pier Analysis and Design, including Cap, Column and Footing Design
Trial
[Image: 48419445325854595840.gif]
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
[-] The following 34 users Like BennyP's post:34 users Like BennyP's post
  โ€ข kowheng, mulham lee, sonidero, cordoba123, Djulaiman, Mohoh77, Dell_Brett, faros3000, panchotevi, cve_jule, dajabar, MEKKAWI, Aiyub, bhowmik, vutuyen, oanm2000, ali akbar, NICKNICK, sudershan, ALSKERT, allagui10, ilgar, Adam Smith, melkat, ChisTeam, mahfuzbangla, cheo.smith, spat, bigone, mecheil.edwar, bhawk0, mahyarov, blaze, dquan373
  Bentley GEOPAK Civil Engineering Suite V8i (Version 08.11.09.903 er.shyams 0 4,736 06-27-2018, 08:27 AM
Last Post: er.shyams
  Portable Bentley RAM Connection V8i (SELECT Series 3) 7.3.1 jamildear4u 4 17,046 09-25-2017, 06:25 PM
Last Post: Aviator
  Bentley RM Bridge Advanced + V8i 08.11.28.02 Williams 1 7,434 12-26-2016, 10:44 AM
  LEAP Bridge Steel CONNECT Edition 16.01.00.05 TAFATNEB 0 5,348 09-16-2016, 08:34 AM
  Bentley LEAP Bridge V8i SS7 14.00.00.19 rami1976 0 5,536 03-24-2016, 05:10 AM
  Bentley LEAP CONSPLICE V8i SS2 01.03.00.03 rami1976 0 6,063 12-13-2015, 08:13 PM
  Bentley WaterGEMS v8i Select series 5(08.11.05.61) emmi 2 10,781 09-28-2015, 08:38 PM
Last Post: jokerโ„ข
