Civil Engineering Association eBooks Structural Books Concrete PCA: Rectangular Concrete Tanks
 noelda2
User ID: 466
Threads: 21
Likes: 387 in 29 posts
Given Likes: 26
09-17-2009, 04:33 AM (This post was last modified: 12-15-2011, 08:55 PM by usman.)
Rectangular Concrete Tanks - PCA
[Image: 00041386730287796719.jpg]
anybody have a copy of the design of rectangular and or circular tank concrete design by the Portland Cement Association (PCA) ...pls share....thanks noelda2
Moderator Addition
[-] The following 2 users Like noelda2's post:2 users Like noelda2's post
  â€¢ waterman57, Nilupa
 noelda2
User ID: 466
Threads: 21
Given Likes: 26
12-09-2009, 09:20 PM (This post was last modified: 04-26-2010, 01:08 AM by concreteok.)
26/4/10 link refreshed
[-] The following 19 users Like noelda2's post:19 users Like noelda2's post
  â€¢ haze, leithowsky, zrilek, fashion, Galileo, Alexander, hanyosman, raad kamil, super_engineer, peixoto, rendel_©, erick, defmere, imran, cesar3226, jgarciafic, malc, ajmf77, Nilupa
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42508
07-15-2010, 10:09 AM (This post was last modified: 02-03-2011, 03:26 AM by usman.)
incomplete book, includes tables and considerations to design
While cylindrical shapes may be structurally best for tank construction, rectangular tanks frequently are preferred for specific purposes. Special processes or operations may make circular tanks inconvenient to use. When several separate cells are required, rectangular tanks can be arranged in less space than circular tanks of the same capacity. Tanks or vats needed inside a building are therefore often made in rectangular or square shapes. For these and other reasons, breweries, tanneries, and paper mills generally use rectangular tanks.
Data presented here are for design of rectangular tanks where the walls are subject to hydrostatic pressure of zero at the top and maximum at the bottom. Some of the data can be used for design of counterforted retaining walls subject to earth pressure for which a hydrostatic type of loading may be substituted in the design calculations. Data also can be applied to design of circular reservoirs of large diameter where lateral stability depends on the action of counterforts built integrally with the wall.
[-] The following 25 users Like Dell_Brett's post:25 users Like Dell_Brett's post
  â€¢ robertsas, highcivil, meditation, shaqee, boycv, michaelsoe, secure, cardinal85, imran, rudyhera03, cesar3226, jgarciafic, vijayakumkuma, Yasir, zrilek, rezart, sysrq, bhawk0, Grunf, Quantumm, wafiullah, Nilupa, lasalleguy, Svetoslav, techno
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Given Likes: 42508
08-09-2010, 03:33 PM (This post was last modified: 03-20-2011, 06:58 AM by usman.)
Mirror:
[-] The following 12 users Like Dell_Brett's post:12 users Like Dell_Brett's post
  â€¢ essam2109, maad59, Dan888, semenki, kristoffer_89, rohailiyaz, kaungthant, ambrish, eng amin, Nilupa, user, learner20
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1667
02-03-2011, 12:19 AM
Rectangular Concrete Tanks - PCA - US
[Image: 59758273661436240559.jpg]
.tanks
[-] The following 25 users Like mowafi3m's post:25 users Like mowafi3m's post
  â€¢ melkat, lednar_ved, kg85arun, Dell_Brett, zainseiya, kowheng, Alexander, essenza, jorge64, gatob, almadar12, ssi3k, zrilek, blaze, bhawk0, Grunf, chenamoy, wafiullah, cristi, Nilupa, psycin, TAFATNEB, legarleon, ISTRAKTURA, dinu69in
 leong8929
User ID: 786
Threads: 24
Likes: 385 in 18 posts
Given Likes: 7
03-20-2011, 06:23 AM (This post was last modified: 12-15-2011, 08:54 PM by usman.)
PCA Rectangular Concrete Tanks
[Image: 73027477762271398738.jpg]
This document showcases analysis and design for rectangular tanks containing fluids. Describes the analysis procedure and provides vastly expanded design tables of coefficients for moments, shears, and deflections due to uniform and triangular loads.
Presents analysis methods for rectangular tanks containing fluids. Describes the analysis procedure and gives tables of coefficients for moments, shears, and deflections due to uniform and triangular loads. Support conditions considered are free and hinged tops as well as hinged and fixed bases. Also covered is durability, minimum reinforcement, crack control, formwork considerations, and multi-cell tanks. Comprehensive design examples illustrate the use of the tables and design aids.
[-] The following 58 users Like leong8929's post:58 users Like leong8929's post
  â€¢ kowheng, usman, RedHorse, subin91, zainseiya, almadar12, mz55, ruaumoko, fashion, miquan, knrsa, Dell_Brett, Pinkto, oanm2000, mma87, foxxx2010, ssi3k, seriousboy, DamaD, user, orambo, yutt, robertsas, malc, peixoto, zrilek, lasalleguy, cristi, wa_sin_29, jgarciafic, paulocs, phamtanvinh, monter, pssst, Mouh@ndiss, tarekamin1972, ranger, henrycv, Galileo, dinu69in, gatob, faros3000, chino1409, vvvv, engr1900, toa011, nuttapolk, bslu_2000, ajmf77, Nilupa, ysooo, saif.mulla, simanta, learner20, Alexander, teo912009, febo927, blaze
 niki102
User ID: 8143
Threads: 82
Likes: 2,495 in 189 posts
Given Likes: 845
08-05-2011, 04:26 PM (This post was last modified: 08-05-2011, 04:27 PM by niki102.)
Size: 5.3 MB | Format: PDF
[Image: comments.png]
Reduced Size
MirroRS By CivilEA Uploader Team
[-] The following 21 users Like niki102's post:21 users Like niki102's post
  â€¢ sodapas, shaqee, Dell_Brett, vic_med, chino1409, pedzaquino, oanm2000, engr1900, toa011, Jackass, chenamoy, Nilupa, ISTRAKTURA, waterman57, Dan888, narendra, learner20, moody1978, knrsa, inge911, Cris Driaza
  PCA: Circular Concrete Tanks without Prestressing mowafi3m 2 3,943 06-12-2018, 12:10 PM
Last Post: febo927
  Theory and Design of Reinforced Concrete Tanks mowafi3m 0 2,162 06-28-2014, 07:08 PM
Last Post: mowafi3m
