Civil Engineering Association Forum Discussion FAQs, Q&A, comments changing background color
 ascetic19
User ID: 100
Threads: 16
Likes: 498 in 65 posts
Given Likes: 673
05-23-2009, 01:26 PM (This post was last modified: 05-23-2009, 01:27 PM by ascetic19.)
i cant see writings because of background colour of forum theme what can i do?
i am using mozilla and chrome
thanks in advance
[-] The following 1 user Likes ascetic19's post:1 user Likes ascetic19's post
  • jonev
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Likes: 21,197 in 2,356 posts
Given Likes: 4260
05-23-2009, 02:05 PM (This post was last modified: 05-23-2009, 02:06 PM by Administrator.)
because you use classic mode, i fixed it for you.
anyone have problem goto User CP>Edit Option remove check bar of classic mode:
[Image: attachment.php?aid=499]
.jpg   1.JPG (Size: 70.47 KB / Downloads: 133)
[-] The following 9 users Like Administrator 's post:9 users Like Administrator 's post
  • ascetic19, ascetic19, Grunf, Grunf, levanduy, levanduy, jaks, jaks, jonev
 ivanveliki
User ID: 1250
Threads: 38
Likes: 886 in 110 posts
Given Likes: 480
10-10-2009, 01:29 PM
How can I change the font color of the links? All links appear with yellow font on white background and are not visible.
For example:
[Image: mix4vd8094ly5gssv68q.jpg]
[-] The following 1 user Likes ivanveliki's post:1 user Likes ivanveliki's post
  • jonev
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Given Likes: 4260
10-10-2009, 02:27 PM
(10-10-2009, 01:29 PM)ivanveliki Wrote: How can I change the font color of the links? All links appear with yellow font on white background and are not visible.
For example:
i couldn`t understand where happen this problem, please post here an example .
  • jonev
 timosi™
User ID: 3890
Threads: 138
Likes: 5,532 in 394 posts
Given Likes: 1812
10-10-2009, 02:33 PM
For example:
I thinks that in the tag code. It limit all html link. So you can't change color font in the tag code.
Because if you can change font color in tag code, tag code will be tag quote.
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 1 user Likes timosi™'s post:1 user Likes timosi™'s post
  • jonev
 ivanveliki
User ID: 1250
Threads: 38
Given Likes: 480
10-10-2009, 04:45 PM
here is what I see in every post where "code" tag is used:
[Image: th20z8a51lh1ho5mn9os.jpg]
This happened when you did the last forum update. I googled the problem, but I couldn't find how to change the font color in "code" tag without using more complex technics.
I think the problem is in "style.css". Look at this site:
There it is said that in "style.css" the two tags "pre" and "code" may be changed
[Image: wvvqb73dzl68j6tg7omr.jpg]
[-] The following 3 users Like ivanveliki's post:3 users Like ivanveliki's post
  • timosi™, timosi™, jonev
 Administrator
CivilEA Founder
Administrators
User ID: 1
Threads: 258
Given Likes: 4260
10-10-2009, 05:46 PM
dear vanveliki
i have no problem with code tag & links, i saw this topic that you put pic of it & i saw all text in code tag is black, see here:
[Image: mj1w3ojx8rad874hhzpu.jpg]
may be this problem is from your browser,
which browser do you use?
do other user have same problem?
  • jonev
 ivanveliki
User ID: 1250
Threads: 38
Given Likes: 480
10-10-2009, 06:46 PM
I am using Firefox 3.5.3
Maybe the problem is in the browser. I will check to see if something pops up.
  • jonev
 timosi™
User ID: 3890
Threads: 138
Given Likes: 1812
10-10-2009, 11:51 PM
(10-10-2009, 06:46 PM)ivanveliki Wrote: I am using Firefox 3.5.3
Oh, dear friend
I am using firefox 3.5 and there is no problem.
regard
1.Follows the rules
4.Do not spam
[-] The following 7 users Like timosi™'s post:7 users Like timosi™'s post
  • Dell_Brett, Dell_Brett, Administrator , Administrator , niki102, niki102, jonev
  [PROBLEM] How to change the forum background color from black to other colors myplaxis 1 9,117 07-19-2015, 04:06 AM
Last Post: ykhackhack
