Civil Engineering Association eBooks Structural Books Concrete Formwork for Concrete by M K Hurd (ACI SP4)
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
05-24-2010, 02:41 AM (This post was last modified: 08-18-2017, 01:25 AM by usman. Edit Reason: N/A )
Formwork for Concrete - M K Hurd(ACI SP4)
Title: SP-4(7TH): Formwork for Concrete
Author: M.K. Hurd
Year of Publication: 2005
Number of Pages: 500
ACI Special Publication 4, 2005, 500 pp.
This document serves a broad range of information needs with the objective of improving quality, safety, and economy in all types of formwork. For the experienced designer or builder of formwork, it is a ready reference on material properties, design data, and construction suggestions. For the architect or engineer, it adds guidance relating to structural design details and the problems and possibilities of executing them in formwork. For the novice, the book explains basic design principles and provides an introduction to many common formwork practices. This edition includes new material on single-sided wall forms, insulating concrete forms, pressure formulas with coefficients for differing weights and mix chemistries, and expanded text on multistory shoring systems.
[Image: 87209933458123741394.jpg]
Links
Regards..
[-] The following 5 users Like Veggeta's post:5 users Like Veggeta's post
  β€’ rohailiyaz, juan.dejuan, Adam Smith, RyanRS, bigone
 toa011
User ID: 9336
Threads: 131
Likes: 6,122 in 224 posts
Given Likes: 3356
07-07-2010, 12:28 AM (This post was last modified: 12-15-2011, 12:04 AM by usman.)
Formwork for Concrete (ACI SP-4)
[Image: 38687165841795074819.jpg]
[Image: 12021427852802954132.jpg]
Item Code: LT212
Date: 2005 Hurd, M. K.
ISBN: 0-87031-177-8
Seventh Edition
Description: Now in its 7th edition, Formwork for Concrete is a reference for designers and builders of formwork on material properties, design data, and construction suggestions. For architects and engineers, it adds guidance on structural design details related to effective formwork; for novices, fundamentals of form design and construction.
The 7th edition, revised in accordance with Guide to Formwork for Concrete (ACI 347R-04), includes new material not available in prior editions on single-sided wall forms, insulating concrete forms, pressure formulas with coefficients for differing weights and mix chemistries, inflated forming methods, and has expanded text on multistory shoring systems. This is the most comprehensive and authoritative formwork reference you can buy! Published by the American Concrete Institute.
Contents:
1. Introduction
2. General Objectives in Formwork Building
3. Overall Planning
4. Materials, Accessories, Proprietary Products
5. Loads and Pressures
6. Form Design
7. Design Tables
8. Formwork Drawings
9. Building and Erecting the Formwork
10. Using the Forms
11. Formwork for Architectural Concrete
12. Shells, Domes, Folded Plates
13. Mass Concrete
14. Tunnels and Shafts
15. Special Techniques in Concrete Construction
APPENDIX
Acknowledgments
Glossary
Guide to Formwork for Concrete, ACI 347-04
ACI 318-03 Code and Commentary-Chapter 6, Formwork, Embedded Pipes, and Construction Joints (Replaced with ACI 318-08 version)
OSHA Regulations, Subpart Q-Concrete and Masonry Construction
Index
Metric Conversion Factors
[-] The following 38 users Like toa011's post:38 users Like toa011's post
  β€’ robertsas, shaqee, Dell_Brett, yucapareja, dajabar, henrycv, Veggeta, Grunf, ascetic19, michaelsoe, hassananas, Galileo, chigozie, DamaD, killoobilloo, cesar3226, oanm2000, concreteok, RICARDI, orambo, Raktim, vic_med, Nilupa, aami32, E123, trungpham, duncan2086, mecheil.edwar, astronet35, sujups, loclong, vannam200588, Umer.Aleem, slowet, arceon, rkce, StaadEng, bigone
Threads: 307
07-07-2010, 07:42 AM
Mirror link:
πŸ‘‰ CLICK HERE πŸ‘ˆ 61.4 MB
If you like the book, buy it! Support the author(s)!
[-] The following 34 users Like Grunf's post:34 users Like Grunf's post
  β€’ kowheng, Dell_Brett, Galileo, verongskey, chigozie, ascetic19, chenamoy, civilteam, rohailiyaz, cesar3226, oanm2000, concreteok, Raktim, cristi, sodapas, Nilupa, aami32, E123, trungpham, bubieng, rcnet, mecheil.edwar, loclong, kkgcivil, a312, jocagalhao, jaejeong, Umer.Aleem, malc, ruaumoko, rkce, StaadEng, erthqkengnrβ„’, bigone
 lednar_ved
User ID: 13300
Threads: 14
Likes: 454 in 41 posts
Given Likes: 1289
02-13-2011, 11:19 AM (This post was last modified: 02-26-2012, 09:10 AM by Grunf.)
Brother,
there you go.
Enjoy!
[-] The following 16 users Like lednar_ved's post:16 users Like lednar_ved's post
  β€’ kowheng, dinu69in, hugoreynal, ascetic19, usman, NBZ1400, Dell_Brett, paulocs, Adam Smith, malc, ssi3k, juan.dejuan, Umer.Aleem, pedzaquino, nuttapolk, bigone
 lednar_ved
User ID: 13300
Threads: 14
Given Likes: 1289
02-26-2012, 08:52 AM
Here's another link...
[-] The following 29 users Like lednar_ved's post:29 users Like lednar_ved's post
  β€’ Dell_Brett, ting tsai huang, slowet, st77bel, eng donny, NBZ1400, nuttapolk, jorgeramos, gulilero, cmepe, concreteok, zego2000, mahyarov, ha893459, chenamoy, bigone, sacem, marion33, isurya, uetian19, subin91, vardan, xdesi, alilo, Jarty, duyhiep83, deovratk, blaze, ptqc06
  Liquid Concrete Pressures and Loads on Formwork rigid_joint 3 4,700 06-03-2016, 12:10 PM
Last Post: scorpion07
  Formwork for Concrete Structures - R. Peurifoy & G. Oberlender toa011 10 8,191 01-13-2016, 12:20 AM
Last Post: eszb
  Concrete Formwork Systems abudabeeja 4 4,065 01-07-2015, 04:35 AM
Last Post: Veggeta
  Effects of Formwork Surface Materials on Concrete Lateral Pressure 2824 1 1,863 03-10-2011, 11:10 AM
Last Post: melkat
  Formwork for Concrete ranger 0 2,309 02-12-2011, 12:36 PM
Last Post: ranger
  Design and Construction using insulating Concrete Formwork gboyega 0 2,929 08-25-2009, 07:21 AM
Last Post: gboyega
