Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem robot spread sheet calculator 2011
 rohailiyaz
User ID: 925
Threads: 146
Likes: 1,152 in 117 posts
Given Likes: 733
05-22-2010, 04:55 AM
in previous versions there were default modules available in spread sheet for calculation. i cant open any library (module) in this version. Can anyone guide me?
[-] The following 2 users Like rohailiyaz's post:2 users Like rohailiyaz's post
  • ahmed73, imran
 warrior68
User ID: 1806
Threads: 1
Likes: 59 in 6 posts
Given Likes: 48
05-22-2010, 07:07 AM
HI
same problem dear , Hope someone will help us very soon :wacko2:
 jcbv
User ID: 19792
Threads: 31
Likes: 962 in 84 posts
Given Likes: 7825
05-22-2010, 08:11 AM
(05-22-2010, 07:07 AM)warrior68 Wrote: HI
Use Autodesk Robot Structural Analysis 2011 SP1 from CIVILEA Autodesk Products.
Threads: 1,128
05-22-2010, 08:41 AM
Happy to see a new user knows how to search the forum and knows how to read (and many old ones don't). I didn't answer you before because i spent my time to install the soft for creating those screenshots. I hope it's what you want and it's enough to convince you.
[Image: 61026988367023349398.gif]
[Image: 45722814856374188369.gif]
[Image: 02369131907023389574.gif]
  • jcbv
 rohailiyaz
User ID: 925
Threads: 146
Given Likes: 733
05-22-2010, 08:42 AM
well i did install that but its still not working as shown in picture below
[Image: 55572459316084570892.jpg]
 warrior68
User ID: 1806
Threads: 1
Given Likes: 48
05-22-2010, 11:13 AM
In my installation I used Robot Structural Analysis 2011 SP1 from CIVILEA But the problem is the same .I think ther's a problem with office or something like that I'm working on it
if I got anything new I'll post it
thanks to all :preved:
Threads: 1,128
05-22-2010, 02:23 PM
The only problem with office is this update but it is limited for one spreadsheet only.
[Image: 75416283225472440730.gif]
When the spreadsheet add-in stop working even repairing Office don't help. When the add-in stop you cannot close Excel and need to stop processes Excel and EsopStart in task manager.
I can tell you, after a few hours after posting the previous screenshots the add-in stop working. After repairing the robot (Control Pannel/Add or Remove Programs... Change/Repair it commeback working. When the software works you must see In the Robot Menu:
[Image: 04961464565338295985.gif]
and in the spreadsheet even when opening the spreadsheet alone from other programs menu in Program Files.
[Image: 63770469304076203375.gif]
The active proccesses will be Excel, EsopStart and EsopApp and not only the first two proccesses.
When the application don't works you will see in Add-ins only the last row (Add-ins Manager) and a normal window of Excell without added menus as in the screenshot above. I repeat in this case you cannot close Excel normaly but using the Windows Task Manager.
I don't know what is the reason of this phenomenon but after repairing the Robot it disappear.
  • LadaHitam
 mm230990
User ID: 5149
Threads: 10
Likes: 125 in 22 posts
Given Likes: 81
05-24-2010, 09:41 PM
Hi;
run also : EsopSetup.exe directly from directory it was installed
with marked :
1. Operation -> Register
2. Components -> fill all three fields
3. Run SC after close
4. Apply&Close
....It should help :preved:
[-] The following 1 user Likes mm230990's post:1 user Likes mm230990's post
  • rohailiyaz
 rohailiyaz
User ID: 925
Threads: 146
Given Likes: 733
05-27-2010, 08:37 AM
@mm230990 i followed your instructions but it is still not working
 yapidizayn
User ID: 4188
Threads: 2
Likes: 8 in 3 posts
Given Likes: 18
#10
05-27-2010, 10:42 AM
I can`t see this excel sheet link. Where is the link? Where can I download an excel programs link.
Thank you in advance.
Pages (3): 1 2 3 Next »
  Autodesk Robot Structural Analysis 2011 bug RazvanMelek 2 7,304 08-14-2010, 06:56 AM
Last Post: RazvanMelek
