Civil Engineering Association eBooks Structural Books Steel Behaviour and Design of Steel Plated Structures
 Bmartin
User ID: 18368
Threads: 12
Likes: 315 in 23 posts
Given Likes: 25
04-27-2010, 01:12 PM (This post was last modified: 11-06-2014, 09:05 AM by lisine.)
[Image: 20418642101154768924.jpg]
This book is the outcome of eleven years of continuous effort (1974-1985). Late in 1973, some members of Technical Committee 8 (Stability) of the ECCS (at that time chaired by Dr. D. SFINTTSCO), decided to create a Technical Working Group called PLATE BUCKLING, in order to promote knowledge in the field of steel plated structures as used 1n structural engineering. One main original aim was the development of research work in the general field of stiffened and unstiffened plate elements, enabling the preparation of a set of European Design Recommendations covering problems in plate and box girders. The language used in all documents and discussions had to be exclusively English, for obvious reasons of economy. The basic format adopted was. that of limit states. This decision was greatly influenced by the four big accidents which had occured, between 1969 and 1971, to box girder bridges in the process of erection and by all the subsequent enquiries and studies.
[-] The following 25 users Like Bmartin's post:25 users Like Bmartin's post
  â€¢ kowheng, ziggywas1, Vladimir, Onga, telefere, cristi, jferrer, Ultra Zone, chenamoy, wa_sin_29, rendel_©, subin91, mafiyaboss, sodapas, baikur, toshi615, durden, lednar_ved, apocalipse, Hengki, miquan, RICARDI, blaze, ting tsai huang, cowboy
 ssobhan
User ID: 1054
Threads: 224
Likes: 8,975 in 1,182 posts
Given Likes: 2465
07-13-2014, 02:47 PM
Diect link;
[-] The following 21 users Like ssobhan's post:21 users Like ssobhan's post
  â€¢ apocalipse, Jackass, warlord1, gulilero, Mohammad6299, Dell_Brett, jcbv, warbeast, malc, mastermind, slowet, ruaumoko, vardan, draluka, PinkPant, GMianG, adams, odiclas, zrilek, oanm2000, bridgeengineer
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
11-06-2014, 02:57 AM
#2 direct link valid
alternative
concrete solution advocate
[-] The following 9 users Like concreteok's post:9 users Like concreteok's post
  â€¢ amindoxiti, zrilek, PinkPant, jcbv, Mohammad6299, oanm2000, bridgeengineer, Dell_Brett, harsono
  Behaviour and Design of Steel and Composite Connections in Fire carolinandra 0 3,334 01-10-2023, 12:16 AM
Last Post: carolinandra
  Steel Structures Design; For Lateral and Vertical Forces carolinandra 3 4,659 01-07-2022, 02:44 AM
Last Post: Veggeta
  Ductile Design of Steel Structures 2nd lamkin 8 8,012 09-06-2021, 04:15 AM
  Ultimate Limit State Design of Steel-Plated Structures apocalipse 2 3,230 11-19-2020, 03:16 PM
Last Post: Kurucz
  ECCS - European Recommendations for the Design of Simple Joints in Steel Structures agelos100 0 1,965 05-14-2020, 09:19 AM
Last Post: agelos100
  Advanced Steel Design of Structures carolinandra 1 2,600 01-08-2020, 08:58 AM
Last Post: kirankumarklk
  Design of Joints in Steel and Composite Structures amindoxiti 3 3,928 12-17-2019, 06:53 AM
