Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) SCI: Steel Building Design Guide Documents
 samjenkins
User ID: 15992
Threads: 2
Likes: 18 in 2 posts
Given Likes: 0
04-06-2010, 07:26 PM (This post was last modified: 12-13-2011, 10:28 PM by usman.)
SCI Steel Building Design Guide Documents
The latest (2010) documents produced by the SCI according to EC3 for steel construction
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
[-] The following 17 users Like samjenkins's post:17 users Like samjenkins's post
  โ€ข toa011, oanm2000, Iktinos, ruaumoko, Dell_Brett, kowheng, robertsas, avscorreia, vvvv, subin91, trdnhiem, funmate69, julioreptil, leetse, zrilek, r3be1, Mohoh77
 metalgun
User ID: 13004
Threads: 3
Likes: 45 in 5 posts
Given Likes: 21
04-07-2010, 03:21 AM
direct link from CORUS CONSTRUCTION WEBSITE:
cheers!
[-] The following 14 users Like metalgun's post:14 users Like metalgun's post
  โ€ข robertsas, Grunf, Dell_Brett, vvvv, texv, jorgeramos, dinu69in, Albert, baikur, leetse, zrilek, Mohoh77, we_mbm, Hengki
 jorgeramos
User ID: 3729
Threads: 20
Likes: 229 in 29 posts
Given Likes: 344
09-04-2010, 07:08 PM (This post was last modified: 09-06-2010, 08:33 AM by Grunf.)
This publication presents design data derived in accordance with the following Parts of Eurocode 3
and their National Annexes
* BS EN 1993-1-1:2005: Design of steel structures. Part 1-1: General rules and rules for buildings.
* BS EN 1993-1-5:2006: Design of steel structures. Part 1-5: Plated structural elements.
* BS EN 1993-1-8:2005: Design of steel structures. Part 1-8: Design of joints.
Where these Parts do not give all the necessary expressions for the evaluation of data, reference is made to other published sources.
The resistances in this publication have been calculated using the partial factors for resistance given in the UK National Annexes for the Eurocode (NA to BS EN 1993-1-1:2005 as published in December 2008, NA to BS EN 1993-1-5:2006 as published in May 2008 and NA to BS EN 1993-1-8:2005 as published in November 2008). The partial factors are listed in Section 5.1. The other
parameters given in the National Annex that have been used when calculating member resistances are given in the relevant section of this publication.
The following structural sections are covered in this publication:
* Universal beams, universal columns, joists, bearing piles, parallel flange channels and
structural tees cut from universal beams and universal columns to BS 4-1
* Universal beams and universal columns produced by Corus but not included in BS 4-1
* Asymmetric Slimflorยฎ beams (ASB) produced by Corus
* Equal and unequal angles to BS EN 10056-1
* Hot-finished structural hollow sections to BS EN 10210-2
* Cold-formed structural hollow sections to BS EN 10219-2
Section ranges listed cover sections that are readily available at the time of printing. The preparation and editorial work for this Edition was carried out by Miss E Nunez Moreno and Mr E Yandzio, both of the SCI, with technical assistance from Mr A S Malik of the SCI and Mr C M King, formerly of the SCI. The project was coordinated by Mr D G Brown, also of the SCI.
The work leading to this publication has been jointly funded by Tata Steel Europe*, SCI and BCSA and their support is gratefully acknowledged.
[-] The following 14 users Like jorgeramos's post:14 users Like jorgeramos's post
  โ€ข jcbv, toa011, Dell_Brett, GROUT, kowheng, lamkin, vvvv, roaming79, Trishu999, oanm2000, Parana34, robertsas, cordoba123, blaze
 apocalipse
Portugal
User ID: 41527
Threads: 65
Likes: 790 in 87 posts
Given Likes: 922
01-28-2013, 09:35 PM
Dear member,
Someone please upload the book design data.
Thank you,
apocalipse
  โ€ข
Threads: 49
01-29-2013, 06:09 AM
@apocalipse - see here:
  โ€ข blaze, st77bel, apocalipse, zrilek
  BS 6093:2006 Design of joints and jointing in building construction. Guide ir_71 1 2,733 09-21-2012, 05:35 PM
