Civil Engineering Association eBooks Journals, Papers and Presentations Plastic Design of Semi-Rigid Frames
Thread Closed
Away  preceptor
Senior Member
User ID: 8148
Threads: 119
Likes: 1,499 in 170 posts
Given Likes: 44
12-17-2009, 05:56 PM (This post was last modified: 04-04-2010, 09:49 PM by Grunf.)
[Image: 09245168550686603024.jpg]
Checks for ultimate strength of frames with partially restrained connections require that the non-linear connection characteristics and the P-~, effects be appropriately modelled. This complexity is unwarranted for preliminary design but few alternatives exist. In this paper an alternate approach, utilizing a second-order plastic analysis method called the mechanism curve (Horne and Morris, 1982), is described. This approach results in a simple and reliable estimation of the collapse capacity of the frame. It was found that this ultimate capacity seldom controls since limitations of drift at service loads results in strong, stiff structures that provide an adequate safety margin against stability failures,
Edit reason: Dead link removed. (G)
[-] The following 6 users Like preceptor's post:6 users Like preceptor's post
  • zrilek, mad_world, soringer, Slide Zone, psa_1987, levanduy
04-04-2010, 02:10 PM
Dear all,
I can't find the article, but the reference to it can be found in the book named Handbook of Structural Engineering, Second Edition posted here:
Best regards
G
[-] The following 1 user Likes Grunf's post:1 user Likes Grunf's post
  • Dell_Brett
  Vulnerability evaluation and seismic rehabilitation of steel building with semi-rigid TAFATNEB 0 3,805 05-09-2014, 10:22 AM
  DETAILING OF PLASTIC HINGES IN SEISMIC DESIGN OF CONCRETE STRUCTURES TAFATNEB 0 4,563 04-21-2014, 10:47 PM
  Performance-based plastic design method for buckling-restrained braced frames arshiakh 1 5,899 11-28-2013, 11:58 AM
  On the Design of Eccentrically Braced Frames shadabg 0 3,945 07-23-2012, 07:03 AM
Last Post: shadabg
  Evaluation of Plastic Rotation Demands for Earthquake Design of Reinforced Concrete B wafiullah 0 4,532 01-06-2012, 09:03 PM
Last Post: wafiullah
  plastic hinge & plastic hinges detailing mowafi3m 1 5,776 01-13-2011, 09:42 PM
Last Post: Grunf
