Civil Engineering Association eBooks Journals, Papers and Presentations A nonlinear analysis methods for performance based seismic design
Thread Closed
Away  preceptor
Senior Member
User ID: 8148
Threads: 119
Likes: 1,499 in 170 posts
Given Likes: 44
11-02-2009, 10:07 PM
A NONLINEAR ANALYSIS METHOD FOR PERFORMANCE BASED SEISMIC DESIGN
[Image: o2j0tyc7jnpv4n0chl6.jpg]
Earthquake spectra vol.16
august 2000
peter fajfar,M.EERI
Abstract
A relatively simple nonlinear method for the seismic analysis of structures (the N2 method) is presented. It combines the pushover analysis of a multi-degree-of-freedom (MDOF) model with the response spectrum analysis of an equivalent single-degree-of-freedom (SDOF) system. The method is formulated in the acceleration-displacement format, which enables the visual interpretation of the procedure and of the relations between the basic quantities controlling the seismic response. Inelastic spectra, rather than elastic spectra with equivalent damping and period, are applied. This feature represents the major difference with respect to the capacity spectrum method. Moreover, demand quantities can be obtained without iteration. Generally, the results of the N2 method are reasonably accurate, provided that the structure oscillates predominantly in the first mode. Some additional limitations apply. In the paper, the method is described and discussed, and it basic derivations are given. The similarities and differences between the proposed method and the FEMA 273 and ATC 40 nonlinear static analysis procedures are discussed. Application of the method is illustrated by means of an example.
.pdf   peter fajfar.pdf (Size: 166.72 KB / Downloads: 379)
[-] The following 12 users Like preceptor's post:12 users Like preceptor's post
  • kowheng, Dell_Brett, aflv, ziggywas1, attila, babak, ruaumoko, zrilek, soringer, mad_world, kristoffer_89, civilgr
04-04-2010, 01:44 PM
Direct link:
  • Dell_Brett, DamirDz
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,571 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Performance-based seismic assessment of skewed bridges bridgeengineer 0 5,277 04-22-2016, 06:31 AM
Last Post: bridgeengineer
  2nd ATC-SEI Conference on Improving the Seismic Performance of Existing Buildings and RyanRS 0 5,371 10-29-2015, 12:55 AM
Last Post: RyanRS
  Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 6,064 07-19-2015, 07:24 AM
Last Post: Wolverine883
  Performance based earthquake design using the CPT PinkPant 0 5,774 05-14-2015, 08:17 AM
Last Post: PinkPant
  Performance –Based Design emmi 2 7,964 03-24-2015, 10:10 AM
Last Post: ssobhan
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,181 11-15-2014, 02:07 PM
