Civil Engineering Association eBooks Codes, Manual & Handbook Zamil Steel: Design Manual
 rohailiyaz
User ID: 925
Threads: 104
Likes: 1,152 in 117 posts
Given Likes: 733
03-12-2010, 06:16 AM (This post was last modified: 12-29-2011, 06:35 PM by usman.)
Zamil Steel Design Manual DM 3.10
This revision of design manual has been prepared to account for the changes of ZAMIL STEEL standards
during the last four years since 1999 regarding single skin & Tempcon panels, built-up sections standard
dimensions, serviceability consideration and some standard connections, also this revision of design
manual presents the results of special technical studies carried out in the ZAMIL STEEL PRD department
including finite element studies using most recent software techniques, buckling analysis studies and also
derived formulas using numerical correlation studies. Designers can make use of these studies to enhance
the design process.
This revision of the design manual also resolves some miscellaneous and confusing points that were
reported to PRD department.
The contents of this manual were rearranged and presented in β€œAdobe Acrobat” format along with
navigation pane to ensure effective and fast use of this manual.
Design/Quote engineers are strongly advised to read this manual as a whole in conjunction with the
standard codes and manuals stated in clause 2.1 page 2-1 of this manual.
The clauses containing the major changes made in this revision of design manual (DM 03.10.00) are as
follows :-
2.4. Serviceability consideration _________ 2-15
3.5. Expansion Joints __________________ 3-8
3.7. Bracing Systems Arrangement_______ 3-11
4.1.2.1. Built up section _________________ 4-3
4.1.2.2. Galvanized primary members______ 4-5
4.3. Flange braces____________________ 4-22
4.6. Standard Anchor Bolts _____________ 4-67
4.7.8. Crane Beam ___________________ 4-74
5.1. Panels___________________________ 5-1
5.2.1.7. Double β€˜C’ -sections ____________ 5-27
5.2.2. Design Of Roof Purlins ___________ 5-29
5.2.4. Design Of Eave Struts ____________ 5-35
6.1.2. End wall Rafter Design Concept _____ 6-2
6.2.2. End Wall Posts Design Concept _____ 6-6
7.2.3.1 Top Running Cranes ____________ 7-11
7.3. Bracing Design Notes______________ 7-13
8.2.1.2.Connection for Lateral Load _______ 8-2
9.1. Design of Joists ___________________ 9-2
9.3. Design of Beams __________________ 9-7
10.11. Egypt Jobs in Non-Free Zone Areas 10-6
12.1. Drainage______________________ 12-1
[Image: pagesfromzamilsteeldesi.jpg]
Edit reason: dead link deleted. (G)
[-] The following 24 users Like rohailiyaz's post:24 users Like rohailiyaz's post
  β€’ robertsas, engr1900, yutt, kowheng, hsccindia, Dell_Brett, michaelsoe, chigozie, vvvv, hcardenas, levanduy, subin91, pezhmankhan, Juan Hugo, taifur, nhim4mat2006, fer962933, novelsus, Quantumm, Clouseau, m_mostafa14, sivlad, ykhackhack, TAFATNEB
 abudabeeja
User ID: 1245
Threads: 492
Likes: 10,106 in 672 posts
Given Likes: 1271
03-31-2010, 06:42 AM
New link
[-] The following 25 users Like abudabeeja's post:25 users Like abudabeeja's post
  β€’ Grunf, bangch, Dell_Brett, isurya, oanm2000, chenamoy, jferrer, nhim4mat2006, fer962933, qeddy, duazo2009, minhtamk94, highcivil, novelsus, ambrish, wilsonseta, julioreptil, darkdkay, strengr, blaze, Alexander, bigone, sivlad, oreslaw, caifan
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,324 in 678 posts
Given Likes: 1668
01-14-2011, 09:24 PM
Mirror
[-] The following 26 users Like mowafi3m's post:26 users Like mowafi3m's post
  β€’ pedzaquino, orambo, lednar_ved, usman, mrco1124, gatob, almadar12, blaze, Dell_Brett, oanm2000, engr1900, Clouseau, m_mostafa14, adi04, Alexander, bigone, shaqee, sivlad, slowet, yanburak, eliseo.as, ting tsai huang, TAFATNEB, Mohammad6299, jcbv, hatkam
 junaid
User ID: 402
Threads: 197
Likes: 8,170 in 732 posts
Given Likes: 983
04-04-2014, 11:48 AM
[-] The following 14 users Like junaid's post:14 users Like junaid's post
  β€’ ykhackhack, blaze, ting tsai huang, vardan, Mohammad6299, malc, rezart, Dell_Brett, ruaumoko, eliseo.as, araza023, milova, simanta, user108
  Corrugated Steel Pipe Design Manual pelelo 1 2,084 02-28-2018, 01:56 AM
  Steel Forgings: Design, Production, Selection, Testing and Application, Manual ibg0203 1 2,719 11-02-2016, 11:30 PM
Last Post: gulilero
  SCI: Design Manual For Structural Stainless Steel serra 7 6,549 03-23-2016, 02:11 AM
Last Post: concreteok
  Zamil Steel: Erection Manual rohailiyaz 2 3,771 04-04-2014, 11:51 AM
Last Post: junaid
  Zamil Steel: Technical Manual i_kabir 2 4,167 04-04-2014, 11:50 AM
Last Post: junaid
  Extra high strength steel stamping design manual legarleon 0 1,846 11-19-2009, 04:39 PM
Last Post: legarleon
