Civil Engineering Association Software Software Product Autodesk Products Robot Extensions for Autodesk Robot Structural Analysis 2010
 mouhandiss
User ID: 187
Threads: 2
Likes: 49 in 2 posts
Given Likes: 0
04-21-2009, 07:12 PM (This post was last modified: 04-22-2009, 02:52 AM by Administrator.)
HI all friends
this link is for Esop 2010
good luck.............................:D:D:P
[-] The following 11 users Like mouhandiss's post:11 users Like mouhandiss's post
  â€¢ Dell_Brett, Dell_Brett, oanm2000, oanm2000, JCMAS, JCMAS, zrilek, zrilek, timosiâ„¢, timosiâ„¢, zdravko
 cod-X
User ID: 45
Threads: 31
Likes: 504 in 63 posts
Given Likes: 269
04-27-2009, 01:53 PM
Composite Design
The extension is used for the Composite Steel Beam design.
The structure elements must fulfill the following requirements:
Beams:
· Must be linear
· Must be AISC Standard Wide Flange shapes
· Must be in plane
· Cannot cross other beams
· Cannot form a circular bearing chain with other members
Slab and all beams must be associated with the same level
Slabs:
· One directional slabs only
· Exactly one slab reinforcing all members in one selection group
· Entire design area must be within slab (no edges inside design area)
· Slab must be planar (no warped slabs)
Loads:
· All point and line loads must be applied to a member in the design area
· Point loads are not counted if they are applied to the end of a member, they are assumed to be supported by whatever is supporting the member
· Point loads at the intersection of more than one member are applied to the first qualifying member only
· Only the component of a load normal to the plane of the design area will be included in the design.
· Unhosted point loads must be applied to a beam element. Note that hosted point loads can only be applied to beam end points in Revit Structure, and are therefore of limited use for analysis
Hosted and Unhosted Line Loads must be applied to a beam element and can be applied without any other limitation.
Hosted and Unhosted Area Loads can be applied to any slab area and can vary in up o one direction. This extensions does not support loads tapered in more than one direction.
· Load from columns are not taken into account. Concentrated loads must be defined by user.
Only DD and LL load cases are managed by this version.
The beam analysis will take place in the plane of the beam (no vibration analysis will be performed). All beams are assumed to be simply supported.
Note that no checks will be made for the capacity of the slab.
Load Takedown
Using the Load Takedown extension, you can perform a simulation of load takedown for vertical forces and stresses caused by these forces in vertical elements of a structure defined in Revit ®.
You can load necessary information from Revit®:
· geometry
· material parameters
· supports
· loads
· load cases
· load combinations.
All results are presented in appropriate tables and on diagrams.
Assumptions:
· Visualization of vertical forces includes:
o for columns: vertical force Fx
o for walls: a sum of vertical forces on the top edge of an element.
· Stresses are calculated using the following formula: vertical force (as specified in point 1) / cross-sectional area.
To perform the load takedown:
· define a structure in Revit ® (with supports, loads and load combinations)
· launch Load Takedown
· modify parameters of supports
· automatically verify the structure
· perform calculations
· analyze the calculation results; you can save the result report in a Microsoft Excel© or Microsoft Word© file (in a mht or html format).
· save reactions on foundations, columns and walls to an rvt file.
>> First learn from cracked software than be licensed1 <<
[-] The following 19 users Like cod-X's post:19 users Like cod-X's post
  â€¢ Administrator , Administrator , kamran, kamran, paulocs, paulocs, thacvu, thacvu, atist, atist, zrilek, zrilek, timosiâ„¢, timosiâ„¢, kowheng, kowheng, lonelyboy, lonelyboy, nuttapolk
 timosiâ„¢
User ID: 3890
Threads: 138
Likes: 5,532 in 394 posts
Given Likes: 1812
09-19-2009, 11:10 AM (This post was last modified: 09-19-2009, 11:13 AM by timosiâ„¢.)
(09-19-2009, 10:30 AM)hvcompxd05 Wrote: Hi,thank you so much for your link!
but,do you have mediafire link?
hvcompxd05
You can try this mediafire link ( mirror link from post #2):
and Second Link:
regard
timosi
Ps: Please click thanks button instead of post a new threat to thanks Cod-X
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
[-] The following 15 users Like timosiâ„¢'s post:15 users Like timosiâ„¢'s post
  â€¢ hvcompxd05, hvcompxd05, zrilek, zrilek, expertvision, expertvision, lonelyboy, lonelyboy, Tensor, Tensor, dadi, ibrim, kaykaysoft, Thanhtung, rkce
  Autodesk Robot 2026 rami1976 0 3,482 05-27-2025, 09:10 PM
  Autodesk 2010 Products Keygen cod-X 6 22,877 03-12-2025, 09:49 AM
  Autodesk Robot Structural Analysis Professional 2024 (x64) Multilanguage TAFATNEB 1 12,734 04-16-2023, 09:52 AM
  Autodesk Robot Structural analysis Professional 2021 rami1976 4 10,495 04-18-2020, 11:52 PM
Last Post: rigid_joint
  Autodesk Robot 2020 structural analysis professional rami1976 2 7,671 04-26-2019, 03:43 AM
  Autodesk Robot Structural Analysis Professional 2019 jokerâ„¢ 2 8,176 09-07-2018, 07:49 PM
  Autodesk Robot Structural Analysis Professional 2018 rami1976 4 12,014 10-11-2017, 07:47 PM
