Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem How to model in etabs with full span opening of shearwall at the bottom.
 rendel_©
Philippine
User ID: 1138
Threads: 115
Likes: 2,115 in 214 posts
Given Likes: 2687
03-07-2010, 05:26 AM (This post was last modified: 03-07-2010, 05:37 AM by rendel_©.)
See below screenshot to make it clear about my question.I have an opening in the bottom of 12 story shearwall, it is due to the ramp.
Can I humbly ask how to model properly the shearwall to have realistic behavior in this case?
Thank in advance..
[Image: 96319846810805226988.jpg]
Another question:
Some etabs model, the support they used is hinges..I usually used fixed support..What is the proper way for the cast in situ.
 jaks
User ID: 2764
Threads: 11
Likes: 258 in 54 posts
Given Likes: 1225
03-07-2010, 05:46 AM
I believe the wall should be modelled as a spandrel to transfer the loads on to the supporting piers. If the wall is continious through 11 floors and then discontinues, I have a doubt about whether it will still act as a spandrel or not. I would rather model it both as a pier and spandrel in different models and check for the behaviour.
I also would like to hear from other experince engineers on this regard.
Jaks.
[-] The following 1 user Likes jaks's post:1 user Likes jaks's post
  • rendel_©
 techno
User ID: 4555
Threads: 86
Likes: 244 in 127 posts
Given Likes: 2286
03-07-2010, 07:13 AM
I am not really understand what is your problem for the 1st question.
Regarding to the 2nd question, if ur project is Pile Foundation then it's better for u to assign as pin support. However, if the given result is more than ur pile capacity then u should assign it as spring since it's much realistic. In our company, we used to assign pile as spring. (Recommended by CSI ETABS Trainner)
For fixed support, u can assign it when u are designing common pad/ combined footing..
[-] The following 1 user Likes techno's post:1 user Likes techno's post
  • rendel_©
 Ultra Zone
Senior Member
El Salvador
User ID: 195
Threads: 98
Likes: 2,410 in 167 posts
Given Likes: 2238
03-07-2010, 02:40 PM
Dear Reynald_d:
1. In some cases it is better to do a manual meshing of the walls, while the mesh is more refined results may be more real. Especially at the intersection between walls.
2. For wall you must use restraints on X, Y and Z.
3. For the wall above the opening, you must design it like a spandrel for the horizontal reinforcement and like a pier for the vertical reinforcement, I mean, you need to have two models.
[Image: 34691433192623148800.jpg]
[Image: 76220071740677100443.jpg]
Follow the Rules
[-] The following 7 users Like Ultra Zone's post:7 users Like Ultra Zone's post
  • faros3000, rendel_©, Dell_Brett, theanhpe, jaks, ruaumoko, eshetu
 iceman84
User ID: 1829
Threads: 26
Likes: 419 in 154 posts
Given Likes: 402
03-07-2010, 08:02 PM
The bottom part of the wall will act like a deep beam, which can be modeled as a strut and tie model. The rest of the wall can be modeled with shell elements.
[-] The following 2 users Like iceman84's post:2 users Like iceman84's post
  • rendel_©, jaks
  model ribbed slab in only grid Etabs pedrozarth 0 5,723 02-01-2010, 07:00 PM
Last Post: pedrozarth
  Etabs model checking rendel_© 4 10,157 08-05-2009, 01:43 AM
Last Post: concreteok
