03-04-2010, 12:37 PM
AVD Weight and Volume Calculator v6.1.1
AVD Weight and Volume Calculator is just the thing for measuring physical parameters of composite objects in 3-D. It calculates weight, volume and mass for the figures of various shapes. The process of calculation is quite simple: after you select the object's shape, just define the sizes with the number of parts and press "ADD" button to get the result.
Features:
· Wide list of geometrical figures;
· Customizable list of the materials;
· Built-in units converter;
· Metrical and Imperial units;
· The result of any calculation can be presented in any units you require;
· Undo and Reset operations;
· Print the results;
· Save the results to a text file.
![[Image: 03479636085817457451.gif]](https://pic.civilea.com/images/03479636085817457451.gif)
