02-12-2010, 04:39 AM
(This post was last modified: 05-08-2023, 10:17 AM by Administrator.)
ACI 349.2R-07 - Guide Embedment Design Examples
Guide to the Concrete Capacity
Design (CCD) Method
Embedment Design Examples - ACI 349.2R-07
This report was prepared by the members of the ACI 349 Subcommittee on Steel Embedments to provide examples of the application of ACI 349 to the design of steel embedments. The first edition of this report, published in 1997, was based on ACI 349-97 that used the 45-degree cone breakout model for determining the concrete breakout strength. The 2001 edition of the Code* marked a major departure from the previous editions with the adoption of the concrete capacity design (CCD) method. The model for the concrete breakout strength used in the CCD method is a breakout prism having an angle of approximately 35 degrees. In addition, the concrete breakout strength for a single anchor away from the edge is proportional to the embedment depth raised to the power of 1.5 and not embedment depth squared, as used in the previous versions of the Code. These and other changes in the Code result in designs that are somewhat different than those obtained using previous editions of the Code. The examples used in this report are based on the ACI 349-06, Appendix D, and illustrate how the CCD method is applied. In previous editions of ACI 349, the anchorage design was given in Appendix B. Because ACI 349 is a dependent code, the chapters and Appendixes in ACI 349 are updated to be consistent with ACI 318.
![[Image: 38827626944601659163.jpg]](https://pic.civilea.com/images/38827626944601659163.jpg)
