Civil Engineering Association Software Software Product Non Engineering Software Easy CurveFit v4.0
Easy CurveFit v4.0
 Gabemzaman
User ID: 2838
Threads: 20
Likes: 1,073 in 79 posts
Given Likes: 379
02-11-2010, 10:07 PM
Easy CurveFit v4.0
Easy CurveFit is a small application designed to allow you to easily plot a curve through any graph of results that you enter into the application.
When first opened, Easy CurveFit is a complete mystery. It's totally unclear what to do with it, as the interface is very abstract and unresponsive. Hovering doesn't give you any clues, and right clicking elicits no response. There is a manual included however, but unfortunately it's very brief and written in bad English that makes little sense!
Basically, to use Easy CurveFit, you have to create a .txt file with your numerical results entered. Then this can be opened, and the points plotted on a graph. You can then, by clicking the various algebraic buttons, create a curve that bets fits your results.
This curve image can be saved, and you can zoom in and out too. While that curve drawing works fine, it's difficult to see what's special about it. While the curve results are good, it's a very clunky interface to use - it would be much improved if you could manually enter results to be plotted, instead of doing so in a text editor first. There are also a distinct lack of options.
If you want to create best fit curves, and save or print your results, Easy CurveFit does the job, but it's not easy to use or well explained at all.
Languages:
English
Limitations:
10 uses
OS requirements for Easy CurveFit:
* OS: Win2000/XP/2003/Vista
[Image: 26105038436497844700.jpg]
[-] The following 12 users Like Gabemzaman's post:12 users Like Gabemzaman's post
  • kowheng, SUSheikh, lucky_b2me, iceman84, osin, ivanveliki, ska51, weather, sudershan, yamacdere, Arigato, sodapas
 ska51
User ID: 11535
Threads: 427
Likes: 9,406 in 1,251 posts
Given Likes: 4017
05-28-2013, 08:37 AM (This post was last modified: 05-28-2013, 08:38 AM by ska51.)
[Image: comments.png]
"Downstream is Weaker"
[-] The following 11 users Like ska51's post:11 users Like ska51's post
  • Dell_Brett, jonny78, blaze, lisine, Arigato, 3fan, ssobhan, usman, fuchiguis, isurya, geomahesh
 ssobhan
User ID: 1054
Threads: 335
Likes: 8,975 in 1,182 posts
Given Likes: 2465
05-28-2013, 07:09 PM
Portable of Easy CurveFit
[-] The following 6 users Like ssobhan's post:6 users Like ssobhan's post
  • Dell_Brett, ska51, usman, malc, utan, Batman07
  CutePDF Writer - create pdf easy 3fan 0 4,521 03-14-2011, 12:43 PM
Last Post: 3fan
