08-03-2009, 05:26 PM
ASTM CODE
ASTM CODE
Download: Code: Content of this section is hidden, You must be registered and upgrade your account to see this content.See this link to read how you can remove this limitation: 👉 CLICK HERE 👈
The following 20 users Like zbizafar's post:• kardels, kardels, timosi™, timosi™, geotecnico, geotecnico, nokiib, nokiib, boy_01, boy_01, koottukaaran, koottukaaran, sopolsing, sopolsing, giovas, ilgar, RAULVB, oanm2000, ziadjordan, sasan7351
09-13-2009, 04:49 AM
(This post was last modified: 09-13-2009, 04:50 AM by koottukaaran.)
Link is not Working
09-13-2009, 05:09 AM
(09-13-2009, 04:49 AM)koottukaaran Wrote: Link is not Workingdear koottukaaran Host 4shared.com was hacked. All link (from this host) doesn't work. Please patience. Tomorrow, problem can be solved. regard timosi
1.Follows the rules
2.Use "Search" before posting 3.Post in the correct sections 4.Do not spam 5.Respect the other members
09-14-2009, 07:06 AM
Looking for this standard;
ASTM E 2397-05 Standard Practice for Determination of Dead Loads and Live Loads associated with Green Roof Systems in volume 4.12, Building Construction. Thanks in advance.
concrete solution advocate
12-11-2009, 11:41 AM
Hi if someone has the following ASTM standards then please post them.
Thanks ASTM C1006 - 07 Standard Test Method for Splitting Tensile Strength of Masonry Units ASTM C1072 - 06 Standard Test Method for Measurement of Masonry Flexural Bond Strength ASTM C1196 - 09 Standard Test Method for In Situ Compressive Stress Within Solid Unit Masonry Estimated Using Flatjack Measurements ASTM C1552 - 09 Standard Practice for Capping Concrete Masonry Units, Related Units and Masonry Prisms for Compression Testing ASTM E519 - 07 Standard Test Method for Diagonal Tension (Shear) in Masonry Assemblages
12-18-2009, 07:06 AM
Information on Dynamic testing of pile is urgently required. if Anyone having ASTM D 4945 08 request you to kindly share.
i know this forum can help me a lot...
02-06-2010, 08:24 AM
Hi All,
Can anyone upload latest ASTM D1143 / D1143M - 07e1 Standard Test Methods for Deep Foundations Under Static Axial Compressive Load. Thanks in Advance
02-10-2010, 07:21 AM
Links are dead, please, could you repost again?
Thanks.
02-19-2010, 09:43 PM
hey everyone.
anyone wiv one of these?thx |
| [REQUEST] ASTM E1300-12ae1? Glass Design | Garylam1029 | 3 | 3,253 |
07-30-2019, 04:48 AM Last Post: concreteok |
| [REQUEST] ASTM D4694 - 09(2015): Standard Test Method for Deflections with a FWD type | utan | 2 | 2,417 |
01-20-2018, 08:10 AM Last Post: ir_71 |
| [REQUEST] ASTM D1143/D1143M - 07 Standard Test Methods for Deep Foundations Under Static Axial | scml2003 | 2 | 2,952 |
03-09-2017, 12:27 AM Last Post: tomtumx |
| [REQUEST] ASTM 2015 Annual Book | abualamal | 0 | 1,669 |
10-10-2015, 03:34 PM Last Post: abualamal |
| [REQUEST] ASTM A706 / A706M - 14 | aslam | 0 | 1,709 |
11-26-2014, 03:43 PM Last Post: aslam |
| [REQUEST] ASTM D-290 -91a and AASHTO T-172 | ervikas34 | 0 | 1,487 |
10-16-2014, 01:15 AM Last Post: ervikas34 |
| [REQUEST] (ASTM STP702) Full-Scale Load Testing of Structures | apocalipse | 0 | 1,625 |
08-19-2014, 08:59 PM Last Post: apocalipse |
