Civil Engineering Association Software Software Product Autodesk Products Autodesk AutoCAD PID V2010 x64
Threads: 274
Likes: 12,075 in 1,233 posts
02-01-2010, 04:46 AM
Create, modify, and manage piping and instrumentation diagrams with AutoCAD® P&ID software. Built on the latest AutoCAD® platform, AutoCAD P&ID is easy to use and familiar to process plant designers and engineers so design teams can begin working immediately with minimal training.
With AutoCAD P&ID, you can streamline and automate common tasks; easily access component and line information; and use tools for the simple reporting, editing, sharing, validating, and exchange of design information so your projects start easier, run better, and finish sooner.
Features:
Project Manager
AutoCAD® P&ID software makes it easy for designers and process plant engineers to set up projects and track revisions. Project-management tools allow the straightforward organization of DWG™ files across an entire project.
Data Manager
Know the impact of external data updates and better validate and manage engineering data throughout a project with this enhanced change-management, viewing, and editing functionality.
Dynamic Lines and Dynamic Components
Simplify many of the detailed design and editing tasks you perform repeatedly every day. Use Dynamic Lines to create, move, and snap lines into place. Reduce the manual breaking and mending of lines with intuitive grip editing and manipulation. Lines automatically break and attach to components that are inserted on, or attached to, the line, and automatically mend when a component is removed.
With Dynamic Components, quickly move and snap components with dynamically linked properties and information into place without the burden of manually editing underlying data.
Reporting and Information Exchange
Use external data sources to easily report, edit, and share piping and instrumentation design project information. Import and export data into formatted data tables as well as various file formats, such as Microsoft® Excel® and .csv. Quickly sort and organize information for easy referencing.
Installation guide:
unpack the files
2.) burn or mount the image
3.) install
4.) Check Readme.txt into Shooters Directory.
[Image: 17779683059910853413.jpg]
[-] The following 1 user Likes pezhmankhan's post:1 user Likes pezhmankhan's post
  • sasan51
Threads: 274
02-01-2010, 10:35 AM
Autodesk AutoCAD PID V2010 x86
And this is 32bit version.
  AutoRebar for Autodesk AutoCAD poolmand 1 12,380 08-18-2025, 09:58 AM
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 5,875 12-02-2024, 01:09 PM
  Autodesk AutoCAD Plant 3D 2022 (x64) Pre-Cracked BennyP 1 10,525 10-27-2023, 04:10 PM
Last Post: Dalvisahi014
  Autodesk AutoCAD 2022 (x64) BennyP 5 13,767 03-29-2022, 11:33 AM
Last Post: Arigato
  Autodesk AutoCAD Civil 3D 2022 poolmand 2 11,663 03-13-2022, 03:04 PM
Last Post: pilitro
  Autodesk AutoCAD Raster Design 2019 BennyP 5 10,835 09-22-2021, 09:07 AM
  Autodesk Autocad 2016 (x64 + x32) Trial BennyP 3 11,584 05-22-2021, 05:55 AM
Last Post: kirankumarklk
