Civil Engineering Association Various Free Discussion New PC advice please
 struceng
Russian Federation
User ID: 258
Threads: 268
Likes: 10,197 in 602 posts
Given Likes: 741
#11
10-20-2009, 07:26 PM
Dear Concreteok,
I only suggest overclocking and raid to expert users of computers. I think again and find no problem giving the configuration here. It is:
Intel Quad Q6600 CPU 4*2.4GHz (~160$)
Gigabyte P35C-DS3R Motherboard (~100$)
Corsair TWIN2X4096-6400C4DHX (~150$)
Zalman CNPS10X Extreme CPU Cooler (~100$)
Cooler Master Storm Sniper Black Chassis (~250$)
3*Seagate 500GB 16MB SATA2 Barracuda 7200.12 HDD (3 * 50$)
Gigabyte Nvidia GeForce 8800GT 512MB VGA (~200$)
and etc.
They are listed by their importance level. This configuration is an old one compared to nowadays parts on the market.
Overclocking this configuration is a long way to go and explain. It takes one week for me to make it stable and select the optimum configuration. Searching and reading a lot from the forums are important. You must test your system for stability with Prime95 for hours. If it crashes then you must change overclocking configuration and start the test again (this is going to repeat again and again :)). Because of that, I should only give you some useful sites and my configuration. I made my configuration from the instructions at the first link.
You must refer to the manual of the motherboard for Raid configuration. It is simple compared to overclocking. When you read the manual you can see that the stripe size of the raid configuration is seleceted during setup. I suggest you to select default one given by motherboard. I think best performance is achieved by Raid0 with 4 disks. You must search forums and read much again. Speeds of some raid configurations are given at this link:
My configuration:
Raid0 with 3 disks (stripe size: 64kB)
and for the CPU and memory:
[Image: exm9pidbaih01rkyyvh8.gif]
[Image: t306hk9iuc60atmpb1jf.gif]
Regards.
[-] The following 4 users Like struceng's post:4 users Like struceng's post
  • concreteok, concreteok, niki102, niki102
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Likes: 4,964 in 638 posts
Given Likes: 3501
#12
10-21-2009, 02:14 AM
Hi struceng,
Checked with my local 'experts'. Their advice (both of them knowing me and my computer knowledge well) "You?! DON'T TRY!".
However, thank you very much!
concrete solution advocate
 chisom
User ID: 9581
Threads: 1
Likes: 18 in 2 posts
Given Likes: 0
#13
10-22-2009, 07:34 AM
Hi,
From my opinion you should go with the Intel processor.Because it has more features then the others.And more importance the less price and better performance.
Thanks for sharing this information.
 antonibede
User ID: 10171
Threads: 1
Likes: 11 in 1 posts
Given Likes: 0
#14
10-26-2009, 12:39 PM
Hello
I think PC1 has the same configuration which I am using right now.It is working just amazing.
I think you should go for PC 1.
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Given Likes: 3501
#15
01-28-2010, 01:55 AM
Proposed new workstation. Built for ETABS big model usage.
Intel Core i5 650 3.33 Ghz 8MB
- Intel DP55WB Motherboard
- 4GB PC1333 DDR3
- 640GB SATA HDD 7200Drive
- 1GB Nvidia G240 DDR5
Window7 Home Premium 64Bit
Heavy/expert computer user, kindly comment/advise.
Many thanks/
 PrinceOfHeartz
User ID: 12034
Threads: 6
Likes: 72 in 18 posts
Given Likes: 19
#16
01-28-2010, 12:20 PM (This post was last modified: 01-28-2010, 12:28 PM by PrinceOfHeartz.)
Hi!
Are you looking for an advise/comment?
Quote:Intel Core i5 650 3.33 Ghz 8MB
Are you sure?
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 51
Given Likes: 3501
#17
01-29-2010, 01:14 AM
Dear Prince,
I made a mistake in copying from the quotation (yes, i didn't check further). I guess the processor model run precedence here.
So, i believe it will be Intel® Core™ i5-650 Processor (4M Cache, 3.20 GHz).
If can, pls comment or advise but bear in mind not using this machine for warcraft or whatsoever.
[-] The following 1 user Likes concreteok's post:1 user Likes concreteok's post
  • PrinceOfHeartz
 PrinceOfHeartz
User ID: 12034
Threads: 6
Given Likes: 19
#18
01-29-2010, 07:08 AM
Hi
ETABS can be very heavy on your hardware. Please tell me about your budget if you have one.
Take a look at this one :
It lacks Hyper-Threading but still is very efficient. It is up there with the I7s.
There are probably only two advantages the i5-650 holds over the i5-750, and for the desktop, they are negligible.
The i5-650 has an graphics core bundled in on the die but it is completely pointless as you are buying a discrete graphics card anyway.
The i5-650 will overclock higher than the i5-750 because of the 32nm technology. But it wont make much of a difference and I also know that you are not interested in overclocking which is a good thing.:yes:
Power consumption is another factor. But it doesn't matter because you're a desktop user.
Why the i5-650 won't make any sense over the i5-750?
It only has two cores vs the i5-750's four cores and hyper-threading is better than nothing, but not better than another core.
I very strongly recommend Gigabyte mobos.
A few of them are here:
Go through the list and I will help you to choose the right one. GA-P55A-UD3 is a good option I think. I assume that you wont overclock and Graphics card is a must if you go for this one. But look into the future.. It has got USB 3.0 ports and provides newest Marvell SE9128 high speed SATA3 storage interface with superfast 6Gbps link speed. It supports CrossFireX technology also. And it is cheap.
Money is a big factor when it comes to the other components. I know that money is not a problem for you guys. But I will comment on the other components only after getting a clue about your budget because a variety of products are out there and they're all separated by a thing called money. So it's impossible to recommend one or two products.
Have a nice day!thumbup
Prince
[-] The following 2 users Like PrinceOfHeartz's post:2 users Like PrinceOfHeartz's post
  • concreteok, Dell_Brett
Pages (2): « Previous 1 2
  I need advice on Structural Softwares - Where shall i post? Μηχανικος 2 5,934 04-06-2015, 07:59 AM
Last Post: concreteok
  [PROBLEM] I need some career advice. rony_shawkat 2 6,458 11-23-2014, 10:47 PM
Last Post: ykhackhack
  Advice for Meshfree Finite Element Method freequo 2 5,862 02-12-2012, 07:07 AM
Last Post: yakwetu
  Advice: Softwares to learn over the summer! Aladdins 7 11,359 02-06-2012, 09:46 AM
Last Post: nexus
