Civil Engineering Association Various Free Discussion DJVU to PDF
DJVU to PDF
12-29-2009, 11:54 AM
There is a (simple) way to convert extension DJVU in to PDF but if you do so in some cases PDF e-book will be a bit or "few times a bit" larger than DJVU format.
To convert DJVU in to PDF I use IrfanView program. Just open DJVU file using IrfanView and go File -- > Save as and from the list Save file as select PDF - Portable Document Format, click Save, wait few seconds and this is it...
Here are two links where you can find IrfanView program:
Hope it helps.
Best regards.
G
[-] The following 8 users Like Grunf's post:8 users Like Grunf's post
  • oanm2000, ynopum, Ultra Zone, levanduy, YaqubMughal, Dell_Brett, kardels, avge
 ynopum
Burundi
User ID: 2733
Threads: 26
Likes: 2,399 in 365 posts
Given Likes: 155
12-29-2009, 12:41 PM
Hi neighbour!
IrfanView is a marvelous software (I am using it more than 10 years), and saving as PDF is a nice feature to make multipage files, but I found it strange why someone should reverse convert DjVu to PDF. Usually a scanned book is better to be in DjVu. Adobe's PDF has only advantage if the book is in text/vector/metafile format. If you compare the performance (speed and quality of the book-browsing) WinDjVu is visibly faster than Foxit PDFreader, and of course Adobe's Acrobat. And another advantage is that DjVu is very easy to work with and much faster than PDF on a PocketPC platform . I have some files that before PDF->DjVu they were impossible to be opened on a 128MB, 624Mhz PocketPC. After converting them to DjVu their display is perfect and smooth.
Of course I am considering only raster PDF files, as you are.
Maybe the only advantage of PDF(raster) over DjVu is it can be opened by somebody who has Adobe's Acrobat - and almost everybody has some type of this software.
[-] The following 4 users Like ynopum's post:4 users Like ynopum's post
  • levanduy, Dell_Brett, Grunf, ska51
 Flexi
User ID: 300
Threads: 158
Likes: 5,440 in 422 posts
Given Likes: 110
12-29-2009, 09:47 PM
Hi members,
i agree with ynopum
The quality of djvu-files are almost better than pdf.
There's another way to convert djvu -> pdf by using this small app.
regards
Flexi
[-] The following 5 users Like Flexi's post:5 users Like Flexi's post
  • Dell_Brett, Grunf, ska51, oanm2000, shaqee
12-30-2009, 07:02 AM
Thank you both for sharing those informations - very useful.
@ Flexi:
my antivirus program detects a trojan in file Portable_STDU_Converter_v10850.html:
"Virus or bad content detected. Trojan.IRCBot-3427"
  DJVU format emmi 3 8,247 10-24-2009, 02:30 AM
Last Post: timosi™
