Civil Engineering Association eBooks Journals, Papers and Presentations Finite Element Modeling of Partially Restrained Beam-to-Girder Connections
Away  preceptor
Senior Member
User ID: 8148
Threads: 113
Likes: 1,499 in 170 posts
Given Likes: 44
12-17-2009, 06:03 PM (This post was last modified: 04-04-2010, 02:22 PM by Grunf.)
[Image: 23678827430763656392.jpg]
In recent years the design of steel framed composite floor systems has been controlled more often by serviceability criteria than by strength. It has been suggested that a partially continuous composite floor system would improve serviceability limit states; and that, partially restrained beam-to-girder connections are the key to such a floor system (Rex and Easterling 1994). A research project aimed at developing design methods and criteria for partially restrained beam-to-girder connections and partially continuous floor systems is currently in progress at Virginia Polytechnic Institute and State University (VPI). This paper focuses on a finite element modeling technique that is being used to predict the moment-rotation behavior of various beam-to-girder connections. This method relies heavily on the behavior models of various connection sub-elements (bolts, welds, etc...). These connection sub-element models are also discussed.
Edit reason: Dead link removed. Title of thread adjusted to fit the title of article (G)
[-] The following 5 users Like preceptor's post:5 users Like preceptor's post
  â€¢ zrilek, mad_world, soringer, Slide Zone, Haseeb Jamal
Threads: 307
12-18-2009, 08:04 AM (This post was last modified: 04-04-2010, 02:16 PM by Grunf.)
Mirror links (my upload):
Article can be found in the book Connections in steel structures 3 as well. The book is posted here:
[-] The following 8 users Like Grunf's post:8 users Like Grunf's post
  â€¢ Dell_Brett, kowheng, baikur, zrilek, rohailiyaz, mad_world, civilteam, jcbv
  Evaluation of Concrete Cracking due to Restrained Thermal Loading and Shrinkage wafiullah 2 9,370 11-26-2020, 09:55 AM
Last Post: Dell_Brett
  Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 6,863 03-01-2017, 04:02 PM
Last Post: pezhmankhan
  ConPrimer-2 Finite Element emmi 0 5,256 03-27-2015, 12:59 AM
Last Post: emmi
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,344 10-08-2014, 02:06 PM
  Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 5,226 03-31-2014, 10:46 PM
  FLEXURAL BEHAVIOR OF REINFORCED CONCRETE BEAMS USING FINITE ELEMENT ANALYSIS (ELASTIC TAFATNEB 0 5,186 03-31-2014, 10:22 PM
  III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS TAFATNEB 0 4,237 03-31-2014, 10:11 PM
