Civil Engineering Association Software Software Installation Problems & Bugs Archive Problem Tekla Templates
Tekla Templates
 pepess
User ID: 4634
Threads: 5
Likes: 21 in 9 posts
Given Likes: 54
11-19-2009, 05:03 PM (This post was last modified: 11-19-2009, 05:10 PM by kowheng.)
Hi everybody,
I want to create a multidrawing table layout and i can't find a way to insert at drawing title the name of the assemblies which are contained by the multi-drawing. Does anyone know any solution? Is there any formula or attribute that can do this job?
Thank you!
Moderator's Notes: Post in wrong section. Thread moved to Software Problem.
 wolfib
User ID: 2211
Threads: 4
Likes: 267 in 18 posts
Given Likes: 17
11-19-2009, 05:24 PM
Hmm. Sorry for my bad english.
So I can´t understand everything.
What are you mean with "Name" of assembly?
Name like "Beam" or name of the profile like "HEA..." ?
All tables you can change with the "template editor"
and edit the variables of your wishes.
 pepess
User ID: 4634
Threads: 5
Given Likes: 54
11-19-2009, 05:54 PM
(11-19-2009, 05:24 PM)wolfib Wrote: Hmm. Sorry for my bad english.
Every Assembly has a prefix, and when you create an assembly drawing it will get a name given by the Assembly Prefix of the main part. When you Create the assembly multidrawing, it will contain a number of previously created assemblies inside, and i want that on my layout table to be the list of contained drawings
 pepess
User ID: 4634
Threads: 5
Given Likes: 54
11-20-2009, 12:04 PM (This post was last modified: 11-20-2009, 12:09 PM by kowheng.)
I think you didn't understood me... I want to be able to insert the name of the assemblies which are contained by the multidrawing into the Layout Table. I attached a picture that will explain better what i want to do. Thanks in advance!
Moderator's Notes: Transparent link without code tag
Threads: 1,118
11-20-2009, 12:14 PM
And pepess do you see this post of Admin ?
http://forum.civilea.com/showthread.php?tid=3371
 amol_sadul
User ID: 11250
Likes: 0 in 0 posts
Given Likes: 0
12-08-2009, 08:02 AM
Can any body know about grid lines in tekla structures 13.1 ?
means I wants to know how to create circular grid lines in tekla strcutures 13.1 ?
 xeaheat
User ID: 1665
Threads: 6
Likes: 14 in 7 posts
Given Likes: 32
12-08-2009, 09:41 AM
I want to also make multidrawing material list and bolt list but I dont have multi drawing material list and bolt list template. Does anyone have a samplethis template I will be[/i] so glad to have it thx in advance
 sheb101
User ID: 5471
Threads: 12
Likes: 447 in 35 posts
Given Likes: 163
12-08-2009, 01:57 PM
(12-08-2009, 08:02 AM)amol_sadul Wrote: Can any body know about grid lines in tekla structures 13.1 ?
you can try the attached to create radial grids, not sure if it is what you are looking for.
another alternative is to import a dwg file as a reference model.
regards
 tgbyhn1234
User ID: 2905
Threads: 2
Likes: 20 in 5 posts
Given Likes: 93
12-08-2009, 09:42 PM
Use RadialGrid_v1 as posted above.
OR
for flexibility but more work as described below:
Change work plane using two points. Create single line grid line. Carry-on for all grids. Use construction circles to join in Model & use arc in GA dwgs.
  How can it be drawn different Plan Bracing templates in RISA TOWER. AhmetErdem 0 4,480 07-30-2010, 01:57 PM
Last Post: AhmetErdem
