Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering A response spectrum method for random vibrations
Away  preceptor
Senior Member
User ID: 8148
Threads: 113
Likes: 1,499 in 170 posts
Given Likes: 44
12-01-2009, 08:53 PM (This post was last modified: 08-19-2010, 06:47 AM by Grunf.)
[Image: 78990741411381474343.jpg]
Der Kiureghian, Armen
UCB/EERC-80/15, Earthquake Engineering Research Center, University of California, Berkeley, 1980-06, 46 pages (575/D44/1980)
A response spectrum method for stationary random vibration analysis of linear structures is developed. The method is based on the assumption that the input excitation is a wide-band, stationary Gaussian process and that the response is also stationary. However, the method can also be used as a good approximation for the response to a transient stationary Gaussian input with a duration several times longer than the fundamental period of the structure. Various response quantities, including the mean-squares of the response and its time derivative, the response mean frequency, and the cumulative distribution and the mean and variance of the peak response, are obtained in terms of the ordinates of the mean response spectrum of the input excitation and the modal properties of the structure. The formulation includes the cross correlation between modal responses, which are shown to be significant for modes with closely spaced natural frequencies. The proposed procedure is demonstrated for an example structure that is subjected to earthquake-induced base excitations. Computed results based on the response spectrum method are in close agreement with simulation results obtained from time-history dynamic analysis. The significance of closely spaced modes and the error associated with a conventional method that neglects the modal correlations are also demonstrated through this example.
[-] The following 19 users Like preceptor's post:19 users Like preceptor's post
  â€¢ oanm2000, adhikarig, Dell_Brett, zrilek, levanduy, aflv, kowheng, ziggywas1, mad_world, riprap, Albert, soringer, plamxd, hrmarin, fer962933, zainseiya, gulilero, triance, terrorruban
Threads: 307
12-17-2009, 06:34 AM (This post was last modified: 03-25-2010, 06:21 PM by Grunf.)
New links:
[-] The following 17 users Like Grunf's post:17 users Like Grunf's post
  â€¢ abudabeeja, riprap, Dell_Brett, baikur, zrilek, carlofabie, muki5, robertsas, civilteam, hsccindia, fer962933, pezhmankhan, engrasad, julioreptil, zainseiya, dinu69in, gulilero
Threads: 57
06-24-2012, 07:40 AM
PDF 2.22 MB
[-] The following 11 users Like kowheng's post:11 users Like kowheng's post
  â€¢ jcbv, malc, melkat, triance, zrilek, seriousboy, terrorruban, mgdario, draluka, Dell_Brett, Wijono
  Random Vibration amindoxiti 0 1,741 02-22-2017, 06:01 AM
  Random Vibration of Structures miquan 5 4,302 12-17-2014, 12:49 PM
  Random Vibrations: Analysis of Structural and Mechanical Systems Grunf 5 4,126 12-17-2014, 12:45 PM
  Response Spectrum Method in Seismic Analysis and Design of Structures parhyang 4 5,644 06-18-2014, 06:01 AM
Last Post: bigone
  Stochastic Processes and Random Vibrations: Theory and Practice cace-01 1 1,945 01-15-2013, 05:03 PM
Last Post: ssobhan
  Multiple support response spectrum analysis vttrlc 1 2,482 03-23-2011, 10:17 AM
