Civil Engineering Association eBooks Codes, Manual & Handbook DESIGN GUIDE FOR HIGH STRENGTH CONCRETE TO SINGAPORE
 legarleon
User ID: 5562
Threads: 10
Likes: 71 in 13 posts
Given Likes: 200
11-15-2009, 08:08 AM (This post was last modified: 05-04-2011, 04:58 PM by usman.)
DESIGN GUIDE FOR HIGH STRENGTH CONCRETE TO SINGAPORE STANDARD
[Image: 61724343225433605343.jpg]
This design guide serves to extend the use of concrete beyond Grade 60 in the design of concrete structures using CP65. Hence, it is intended for use by engineers familiar with the design of concrete structures using particularly CP65 but who have little or no experience of high strength concrete (HSC). The guide is intended to provide safe design guidance, based on the best available information, especially in the areas not adequately covered by CP65.
In this respect, the guidance and recommendations in the Concrete Society Technical Report 49 are very relevant and have been extensively adopted here where ever possible. However, it should be noted that this guidance deals only with HSC made with normal weight aggregates and it should not be use for light weight aggregate concrete.
Download Links:
[-] The following 11 users Like legarleon's post:11 users Like legarleon's post
  â€¢ kowheng, Dell_Brett, oanm2000, giovas, subin91, sangen, zego2000, 3fan, levanduy, techno, sivlad
 rangarajan
Junior Member
User ID: 5376
Threads: 5
Likes: 27 in 7 posts
Given Likes: 60
05-04-2011, 07:51 AM (This post was last modified: 05-04-2011, 07:52 AM by Grunf.)
In the above link it is downloadable.
T.RangaRajan.
[-] The following 11 users Like rangarajan's post:11 users Like rangarajan's post
  â€¢ David90, levanduy, kowheng, oanm2000, kmmh76, legarleon, sivlad, ruaumoko, Nim., KhaLed-S.E, blaze
  [CivilEA Exclusive] Ultra-High Performance Concrete: Design, Performance, and Application babakfeyzi 1 3,728 01-13-2024, 06:13 AM
  LRFD Guide Specifications for Design of Concrete-filled FRP Tubes for Flexural and Ax Mohammad6299 1 2,256 09-01-2014, 07:35 AM
Last Post: pezhmankhan
  Singapore Standard CP65 wahta 6 5,641 05-12-2014, 06:09 AM
Last Post: concreteok
  Extra high strength steel stamping design manual legarleon 0 1,850 11-19-2009, 04:39 PM
Last Post: legarleon
