Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Distribution of Earthquake Input Energy in Structures
 tarugo
User ID: 201
Threads: 18
Likes: 415 in 55 posts
Given Likes: 154
11-09-2009, 11:18 AM
[Image: 36qx3x2d10hifsbs65v8.bmp]
In developing an energy-based design approach and assessing the damage potential of structures, one must know the distribution of earthquake input energy among energy components: kinetic, elastic strain, hysteretic, and damping. This report examines the influences of the ground motion characteristics: intensity, frequency content, and duration of strong motion and the structural properties: ductility, damping, and hysteretic behavior on the distribution of input energy for a one- and a five-story building using 20 accelerograms, ten with short and ten with long duration of strong motion.
Results indicate that for certain damping ratios, ductility has a significant influence on input energy and its distribution among energy components in a structure. For a given ductility ratio, small damping ratio (less than 5%) has a minor effect on input energy, but a major influence on the energy distribution. Damping ratios larger than 5% have a significant influence on the input energy and its distribution. Three energy ratios that relate to hysteretic energy were computed: the maximum ratio of hysteretic to input energy (Eh/Eir)m, the ratio of the maximum hysteretic energy to the maximum input energy Ehm/Eirm, and the equivalent number of yield excursions Neq=Ehm/(Fy.up) where Fy is the yield strength, and up is the plastic deformation. It is found that (Eh/Eir)m generally reflects the energy demand for the largest yield excursion, and Ehm/Eirm and Neq reflect the energy demand for the entire duration of accelerogram. The study shows that (Eh/Eir)m is independent of the duration of strong motion and period of structure; however, Ehm/Eirm is independent of both only for periods less than 1 s. Results indicate that as the duration becomes longer the equivalent number of yield excursions Neq increases indicating more structural damage.
The influence of ground motion characteristics and structural properties on the distribution of energy parameters for a five-story building with fixed-base, base-isolation, supplemental damping, and semi-active control are examined using the 20 accelerograms. The results show that: 1) the distribution of energy through the height of the building is mostly independent of the frequency content and the duration of strong motion, 2) base-isolation, supplemental damping, and semi-active control reduce the damage potential by reducing the input and hysteretic energy demands and have significant influences on the distribution of energy through the height of the building.
Download Links:
[-] The following 16 users Like tarugo's post:16 users Like tarugo's post
  • timosi™, kowheng, rendel_©, ruaumoko, baikur, vedranius, ajmf77, Grunf, zrilek, amira, cristi, jf28, seriousboy, Sumatra, Clouseau, zainseiya
03-18-2011, 10:46 AM (This post was last modified: 12-15-2012, 07:26 AM by kowheng.)
PDF|ZIP 2.97|1.53 MB
[-] The following 7 users Like kowheng's post:7 users Like kowheng's post
  • Grunf, blaze, Sumatra, usman, Clouseau, zainseiya, zrilek
  An Impulse and Earthquake Energy Balance Approach in Nonlinear Structural Dynamics poolmand 0 1,587 01-03-2022, 08:47 AM
  An Impulse and Earthquake Energy Balance Approach in Nonlinear Structural Dynamics carolinandra 0 1,601 09-19-2021, 06:36 PM
Last Post: carolinandra
  Earthquake Analysis and Design of Industrial Structures and Infra-structures sabooryan 2 3,240 11-13-2018, 03:37 AM
Last Post: al_frd
  Response History Analysis of Structures with Seismic Isolation and Energy Dissipation andre85 0 1,934 02-02-2012, 07:13 AM
Last Post: andre85
