Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI RAP-4: Surface Repair Using Form-and-Pour Techniques
Likes: 8,311 in 1,373 posts
Given Likes: 92
08-28-2024, 06:40 AM
Author(s)/Editor(s): ACI Committee E706 | Size: 1.72 MB| Format: PDF| Quality: Original preprint| Year: 2011
[Image: 60502952333898118305.png]
FIELD GUIDE TO CONCRETE REPAIR APPLICATION PROCEDURES
Surface Repair Using Form-and- Pour Techniques
The form-and-pour placement technique is a multistep process of preparation, formwork construction, and placement of repair materials. Repair materials are placed in the cavity between the formwork and the prepared substrate with
buckets, pumps, chutes, or buggies. The form-and-pour technique allows the use of many different castable repair materials. Placeability is the primary consideration material selection. Depending on the consistency of the repair
material, consolidation is accomplished by vibration, rodding, or when the material has extremely high slump (self consolidating), no additional steps may be required.
  â€¢ babakfeyzi
  ACI RAP-5: Surface Repair Using Form-and-Pump Techniques poolmand 0 1,501 08-28-2024, 06:41 AM
  [CivilEA Exclusive] ACI 364.5: Importance of Modulus of Elasticity in Surface Repair Materials poolmand 0 1,568 11-05-2023, 06:48 AM
