Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI TMS 122.2: Thermal Properties of Concrete and Masonry for Use
Likes: 8,311 in 1,373 posts
Given Likes: 94
05-26-2024, 04:51 AM (This post was last modified: 05-26-2024, 06:48 AM by poolmand.)
ACI-TMS CODE-122.2-24: Thermal Properties of Concrete and Masonry for Use in Determining Energy Code Compliance for Low-Rise Residential Buildingsβ€”Code Requirements and Commentary
| Size: 37.39 MB| Format: PDF| Quality: Scanner| Year: 2024| pages: 112 | ISBN: 9781641952514
[Image: 89410221439149608568.jpg]
This Code prescribes minimum design and construction requirements for energy efficiency of building envelopes of new buildings and additions to buildings. It applies to buildings having concrete walls, roofs, or floors; masonry walls; and masonry veneer, including veneer attached to frame walls as part of the building envelope. It also provides minimum thermal properties for these assemblies for code compliance. This Code is applicable to low-rise residential buildings that use either electricity from any generation source or fossil fuel. It can be used with applicable energy codes and standards such as the International Energy Conservation Code (IECC).
energy efficiency; specific heat; thermal conductivity; thermal diffusivity; thermal resistance; thermal transmittance.
This post has been made by CivilEA Post-Generator V2.4.3
  β€’ babakfeyzi, subin91, PinkPant
  [CivilEA Exclusive] ACI-TMS 122.3: Thermal Properties of Concrete and Masonry for Use in Determining Ener poolmand 0 2,657 12-15-2024, 06:51 AM
  [CivilEA Exclusive] ACI-TMS 122.1: Thermal Bridge Mitigation for Buildings Having Concrete and Masonry poolmand 0 1,644 10-21-2023, 11:59 AM
  ACI 216.1: Fire Resistance of Concrete & Masonry Construction Assemblies nibbi 2 2,895 05-08-2023, 08:44 AM
  ACI 207.2: Report on Thermal and Volume Change Effects on Cracking of Mass Concrete portal61 2 3,828 05-03-2023, 05:26 AM
