Civil Engineering Association Software Software Product Autodesk Products Autocad 2025
Autocad 2025
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Likes: 626 in 97 posts
Given Likes: 1389
03-26-2024, 08:22 PM (This post was last modified: 10-20-2024, 10:16 AM by poolmand.)
Autodesk Autocad 2025
[Image: 41394374700062891084.png]
Description
Autodesk AutoCAD 2024 design and documentation software, of the world’s leading 2D and 3D CAD tools. It will allow you to design and shape the world around you using its powerful and flexible features. Speed documentation, share ideas seamlessly, and explore ideas more intuitively in 3D. With thousands of available add-ons, AutoCAD software provides the ultimate in flexibility, customized for your specific needs. It’s time to take design further.
AutoCAD 2023 enables you to create and explore ideas like never before. It is all you need to create, visualize, document, and share your ideas. From conceptual design through drafting and detailing.
Import a wide variety of other formats including SolidWorks, Pro/ENGINEER, CATIA, Rhino, and NX. Drawing views, edge display, and location are instantly updated when an engineering change is made.
System requirements
OS:Microsoft Windows 10 (64-bit only) (version 1803 or higher)
CPU:Basic:2.5–2.9 GHz processor / Recommended:3+ GHz processor
Multiple processors:Supported by the application
RAM:8 GB / Recommended: 16 GB
Display Resolution
Conventional Displays:1920 x 1080 with True Color
High Resolution & 4K Displays:Resolutions up to 3840 x 2160 supported on Windows 10, 64-bit systems (with capable display card)
Disk space:6.0 GB
[Image: homepage.png]
[-] The following 15 users Like babakfeyzi's post:15 users Like babakfeyzi's post
  • zrilek, Administrator , Dell_Brett, jorgeramos, Bhawk, mowafi3m, odiclas, jcbv, aleph177, jacky899, dangvutuan, eszb, TAFATNEB, jupe01, j0hannes
 jacky899
User ID: 4603
Threads: 24
Likes: 412 in 44 posts
Given Likes: 476
04-08-2024, 05:18 AM
Thank you. The medicine is missing a file "netapi32.dll". It is step 3 in the install.txt.
PHP Code:
3) Replace the netapi32.dll - \Program Files (x86)\Common Files\Autodesk Shared\AdskLicensing\Current\AdskLicensingAgent\
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Given Likes: 1389
04-10-2024, 02:44 PM (This post was last modified: 04-12-2024, 01:27 AM by Dell_Brett.)
Hi
all autodesk 2025 New crack just one click
[-] The following 1 user Likes babakfeyzi's post:1 user Likes babakfeyzi's post
  • Dell_Brett
 ssamis
User ID: 506
Threads: 8
Likes: 62 in 33 posts
Given Likes: 6
04-11-2024, 09:31 AM
Please share again as post#3 did not work
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Given Likes: 1389
04-11-2024, 01:34 PM (This post was last modified: 04-12-2024, 01:26 AM by Dell_Brett.)
Hi new link
just one click. plase read me first
  • PinkPant
 ssamis
User ID: 506
Threads: 8
Given Likes: 6
04-12-2024, 01:04 AM
please mirron on some other site as mediafire gives error as below:
The file you attempted to download was determined to be dangerous. For your protection, MediaFire does not enable distribution of dangerous files.
[-] The following 1 user Likes ssamis's post:1 user Likes ssamis's post
  • Dell_Brett
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Given Likes: 1389
04-12-2024, 02:07 PM (This post was last modified: 04-12-2024, 02:08 PM by babakfeyzi.)
Hi
New Link Autodesk 2025 All product patch
[-] The following 5 users Like babakfeyzi's post:5 users Like babakfeyzi's post
  • zrilek, PinkPant, Dell_Brett, lisine, jacky899
 babakfeyzi
Romania
User ID: 177117
Threads: 15
Given Likes: 1389
04-14-2024, 06:06 PM
New link
[-] The following 6 users Like babakfeyzi's post:6 users Like babakfeyzi's post
  • Dell_Brett, PinkPant, zrilek, jacky899, golpesar, wchum
 rami1976
User ID: 34597
Threads: 341
Likes: 9,524 in 1,138 posts
Given Likes: 1388
04-17-2024, 08:38 AM (This post was last modified: 04-17-2024, 02:56 PM by rami1976.)
Autodesk 2025 - direct links
Autocad 2025
  • zrilek, lisine, jacky899, wchum, golpesar, albani
 rami1976
User ID: 34597
Threads: 341
Given Likes: 1388
#10
04-18-2024, 04:30 PM
Update to Autocad 2025.0.1
[-] The following 7 users Like rami1976's post:7 users Like rami1976's post
  • zrilek, Dell_Brett, lisine, joker™, jacky899, wchum, golpesar
Pages (3): 1 2 3 Next »
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 5,793 12-02-2024, 01:09 PM
