Civil Engineering Association eBooks Codes, Manual & Handbook AWWA AWWA B451 Standard for Poly (Diallyldimethylammonium Chloride)
Likes: 8,311 in 1,373 posts
Given Likes: 92
01-21-2024, 05:43 AM
AWWA B451-23 Standard for Poly (Diallyldimethylammonium Chloride)
| Size: 8.1 MB| Format: PDF| Quality: Scanner| Year: 2023 | ISBN: 9781647171346
[Image: 11148499914153244180.jpg]
The purpose of this standard is to provide the minimum requirements for polyDADMAC products, including physical, chemical, packaging, shipping, and testing requirements, and to provide the means of developing requirements for specific polyDADMAC products.
This standard describes poly(diallyldimethylammonium chloride) for use in the treatment of potable water, wastewater, and reclaimed water. It can be referenced in documents for purchasing and receiving polyDADMAC and can be used as a guide for testing the physical and chemical properties of polyDADMAC samples. The stipulations for this standard apply when this document has been referenced and then only to polyDADMAC used in the treatment of potable water, wastewater, and reclaimed water. Each section or subsection of this standard shall apply to the treatment of potable water, wastewater, and reclaimed water unless the section, subsection, or title states that it applies only to potable water, only to wastewater, or only to reclaimed water.
  â€¢ PinkPant, babakfeyzi
  AWWA B408 LIQUID POLYALUMINUM CHLORIDE poolmand 0 3,149 01-20-2024, 11:56 AM
  AWWA B407 LIQUID FERRIC CHLORIDE poolmand 0 3,067 01-20-2024, 11:54 AM
  AWWA B200: Sodium Chloride poolmand 0 2,927 01-15-2024, 12:35 PM
  AWWA C907: Injection-Molded Polyvinyl Chloride (PVC) Pressure Fittings, 4 In. Through poolmand 0 1,452 01-15-2024, 10:47 AM
