Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 440.11: Building Code Requirements for Structural Concrete Reinforced with Glass
Likes: 8,311 in 1,373 posts
Given Likes: 94
01-08-2024, 08:31 AM (This post was last modified: 01-08-2024, 08:31 AM by poolmand.)
ACI CODE-440.11-22: Building Code Requirements for Structural Concrete Reinforced with Glass Fiber-Reinforced Polymer (GFRP) Bars—Code and Commentary
SI & IN-LB
Author(s)/Editor(s): ACI Committee 440 | Size: 115.45 MB| Format: PDF| Quality: Scanner| Year: 2023| pages: 260
[Image: 99394205740066933064.jpg]
[Image: 43100117029683034758.jpg]
This Code was developed by an ANSI-approved consensus process and addresses structural systems, members, and connections, including cast-in-place, precast, nonprestressed, and composite construction. The “Building Code Requirements for Structural Concrete Reinforced with Glass Fiber-Reinforced Polymer (GFRP) Bars” (“Code”) provides minimum requirements for the materials, design, and detailing of structural concrete buildings and, where applicable, nonbuilding structures reinforced with GFRP bars that conform to the requirements of ASTM D7957-22. Among the subjects covered are: design and construction for strength, serviceability, and durability; load combinations, load factors, and strength reduction factors; structural analysis methods; deflection limits; development and splicing of reinforcement; construction document information; field inspection and testing; and methods to evaluate the strength of existing structures.
admixtures; aggregates; beam-column frame; beams (supports); cements; columns (supports); combined stress; composite construction (concrete to concrete); compressive strength; concrete; construction documents; continuity (structural); cover; curing; deflections; durability; flexural strength; floors; footings; formwork (construction); GFRP reinforcement; inspection; joints (junctions); joists; load tests (structural); loads (forces); mixture proportioning; modulus of elasticity; moments; piles; placing; precast concrete; quality control; reinforced concrete; roofs; serviceability; shear strength; spans; splicing; strength analysis; stresses; structural analysis; structural design; structural integrity; structural walls; T-beams; torsion; walls; water.
[-] The following 7 users Like poolmand's post:7 users Like poolmand's post
  • PinkPant, babakfeyzi, Dell_Brett, subin91, blaze, Umer.Aleem, kowheng
  ACI 318.2: Building Code Requirements for Concrete Thin Shells ir_71 7 6,925 12-06-2025, 11:30 AM
  [CivilEA Exclusive] ACI/PCI 319: Structural Precast Concrete —Code Requirements and Commentary poolmand 2 8,021 09-16-2025, 11:03 AM
  ACI 318: Building Code Requirements for Structural Concrete and Commentary robertsas 81 53,443 08-17-2025, 10:45 AM
  [CivilEA Exclusive] ACI 440.13: Strengthening Structural Concrete with Fiber-Reinforced Polymer (FRP) Sys poolmand 0 2,072 12-15-2024, 06:43 AM
  [CivilEA Exclusive] ACI 349: Code Requirements for Nuclear Safety Related Concrete Structures andersen3 5 6,318 12-15-2024, 06:33 AM
  [CivilEA Exclusive] ACI 323: Low-Carbon Concrete - Code Requirements and Commentary poolmand 0 2,580 12-15-2024, 05:50 AM
  ACI SP-343: Fibre Reinforced Concrete: From Design to Structural Applications poolmand 0 1,924 03-04-2024, 07:50 AM
