Civil Engineering Association eBooks Codes, Manual & Handbook ACI [CivilEA Exclusive] ACI 225.1: Removal of Optional Alkali Limit in Standard Specifications for Portland C
Likes: 8,311 in 1,373 posts
Given Likes: 94
10-25-2023, 08:09 AM (This post was last modified: 10-25-2023, 08:10 AM by poolmand. Edit Reason: N/A )
ACI PRC-225.1-20: Removal of Optional Alkali Limit in Standard Specifications for Portland Cement
Author(s)/Editor(s): ACI Committee 225 | Size: 2.47 MB| Format: PDF| Quality: Scanner| pages: 3
Alkali-silica reactivity (ASR) is a potentially deleterious expansive reaction between alkalies in the pore solution of concrete and certain reactive aggregates. When ASR was first identified as a distress mechanism in the 1940s, cements with equivalent alkali contents below 0.60 percent by mass were shown to reduce the risk of this reaction. Subsequent research has shown that limiting the cement alkali content to 0.60 percent is not always sufficient to control deleterious ASR with every aggregate nor in all concrete mixtures. It is now well accepted that the reactivity of the aggregate and the amount of alkalies available in the concrete are more important in predicting deleterious ASR than cement alkali content alone.
N/A
  â€¢ Dell_Brett, PinkPant, zrilek, babakfeyzi, kowheng, subin91
  ACI RAP-14: Concrete Removal Using Hydrodemolition poolmand 0 1,657 08-28-2024, 07:02 AM
  ACI 364.8: Hydrodemolition for Concrete Removal in Unbonded Post-Tensioned Systems poolmand 0 1,493 05-02-2023, 11:55 AM
  ACI 364.6: Concrete Removal in Repairs Involving Corroded Reinforcing Steel poolmand 0 1,593 05-02-2023, 11:43 AM
  ACI 242: Alkali-Activated Cements poolmand 0 1,784 05-02-2023, 09:47 AM
