Civil Engineering Association eBooks Codes, Manual & Handbook AWS AWS C2.23M/C2.23: Specification for the Application of Thermal Spray Coatings (Metall
Likes: 8,311 in 1,373 posts
Given Likes: 92
08-27-2023, 06:53 AM
AWS C2.23M/C2.23-2018: Specification for the Application of Thermal Spray Coatings (Metallizing) of Aluminum, Zinc, and Their Alloys and Composites for the Corrosion Protection of Steel
| Size: 4.21 MB| Format: PDF| Quality: Scanner| Publisher: American Welding Society, Inc. (AWS) | Year: 2nd Edition, 2018| pages: 31
[Image: 10436776721881215967.png]
AWS C2.23M/C2.23, 2nd Edition, 2018 - Specification for the Application of Thermal Spray Coatings (Metallizing) of Aluminum, Zinc, and Their Alloys and Composites for the Corrosion Protection of Steel
Included are requirements for surface preparation, coating application, repair of coating defects, measurement of coating thickness, adhesion testing of the applied coating, and application of sealers and topcoats over the thermally sprayed metal coating. Not included in this standard are requirements for design and fabrication, thermal spray equipment qualification, coating selection, and operator and inspector certification. For successful thermal spray application, the steel structure and components should be designed and fabricated in accordance with NACE SP0178.1 Additional consideration should be given to weldments and components, or structures with thermal cut edges, whose hardness may preclude adequate profile depth.
(1) American National Standards Institute (ANSI), 1819 L Street NW, Suite 600, Washington, DC, 20036.
  â€¢ babakfeyzi, kowheng, PinkPant
  AWS C4.6M: Thermal Cutting Classification of Thermal Cuts Geometric Product Specifica poolmand 0 1,546 08-30-2023, 08:30 AM
  AWS C2.25/C2.25M: Specification for Thermal Spray Feedstock - Wire and Rods poolmand 0 1,555 08-27-2023, 06:55 AM
  AWS C2.21M/C2.21: Specification for Thermal Spray Equipment Performance Verification poolmand 0 1,443 08-27-2023, 06:34 AM
  AWS C2.19/C2.19M: Specification for the Application of Thermal Spray Coatings to Mac poolmand 0 1,798 08-26-2023, 12:45 PM
  AWS C2.18: Guide for the Protection of Steel with Thermal Sprayed Coatings of Aluminu poolmand 0 1,531 08-26-2023, 12:33 PM
  AWS C2.16/C2.16M: Guide for Thermal Spray Operator Qualification Programs poolmand 0 1,508 08-26-2023, 12:28 PM
