Civil Engineering Association Software Software Product Autodesk Products Autodesk 2024
Autodesk 2024
 rami1976
User ID: 34597
Threads: 355
Likes: 9,524 in 1,138 posts
Given Likes: 1390
#41
08-06-2023, 09:41 PM
AutoCAD 2024.1
[-] The following 4 users Like rami1976's post:4 users Like rami1976's post
  β€’ zrilek, Dell_Brett, jacky899, Vatsalbu89
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1390
#42
08-08-2023, 10:35 PM
AutoCAD 2024 VBA Extension
 zrilek
User ID: 3860
Threads: 10
Likes: 337 in 59 posts
Given Likes: 22028
#43
08-19-2023, 03:50 PM
CFD 2024
  β€’
 zrilek
User ID: 3860
Threads: 10
Given Likes: 22028
#44
08-19-2023, 10:14 PM
Point Layout 2024
[-] The following 2 users Like zrilek's post:2 users Like zrilek's post
  β€’ rami1976, Dell_Brett
Likes: 8,285 in 1,365 posts
Given Likes: 91
#45
10-04-2023, 07:10 AM (This post was last modified: 10-10-2023, 11:41 AM by Administrator. Edit Reason: N/A )
Autodesk 2024 Products Cracks
moderator note:
deleted main link , reason is file deleted
kindly post the right password
  β€’ PinkPant, zrilek, Dell_Brett
 rami1976
User ID: 34597
Threads: 355
Given Likes: 1390
#46
10-09-2023, 10:20 PM
Password is wrong , kindly post the right one
  β€’
Given Likes: 91
#47
10-10-2023, 11:42 AM
(10-09-2023, 10:20 PM)rami1976 Wrote: PasswordΒ  is wrong , kindly post the right one
Mentioned post was updated.
  β€’ rami1976
 jorgeramos
User ID: 3729
Threads: 20
Likes: 229 in 29 posts
Given Likes: 344
#48
01-28-2025, 10:38 AM
Hello fellows,
A systematic problem has been occurring with the pop-up related to the application's genuine service, which prevents work from continuing normally. Has anyone managed to solve this problem?
Thanks
  β€’
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42500
#49
02-04-2025, 10:36 AM (This post was last modified: 02-04-2025, 10:37 AM by Dell_Brett.)
Steps to remove the genuine Autodesk software or genuine Autodesk software alert message
1. Modify the Windows system host file, this is done as follows:
1.1 - In the Windows search engine, open the notepad, and run it in administrator mode, right click "Run as administrator"
1.2 - Find the host file in the following path:
c:\Windows\System32\Drivers\etc\hosts.
1.3 - Once the host file is open, you put the following information:
0.0.0.0 api.genuine.autodesk.com
0.0.0.0 ase.autodesk.com
0.0.0.0 genuine-software.autodesk.com
0.0.0.0 genuine-software1.autodesk.com
0.0.0.0 genuine-software2.autodesk.com
1.4 - Save the host file, reboot the computer and that's it, this should stop sending the genuine software message
2. In case it happens that it blocks the connections, but still shows the window with the following message
"Hmmm....can't reach this page"
because although it is true that it does not establish the connection, it still tries to reestablish one, and it will not let you work in peace
The following steps must be followed:
2.1 - Enter Windows Defender with advanced security
2.1.1 - Once inside, go to "Inbound Rules" and click on "New Rule"
2.1.2 - "Program" (Next); "Path"
C:\Program Files (x86)\Microsoft\EdgeWebView\Application\131.0.2903.146\msedgewebview2.exe
2.1.3 - Block the connection; Next; Next; Finish
Then, follow the same steps for "Outbound Rules"
And that's it... keep working...!!!
[-] The following 3 users Like Dell_Brett's post:3 users Like Dell_Brett's post
  β€’ oanm2000, zrilek, jorgeramos
 jorgeramos
User ID: 3729
Threads: 20
Given Likes: 344
#50
02-08-2025, 06:13 PM
Hello Dell Bret,
1. Does the sequence 0.0.0.0 means an IP address?
2. My firewall is controlled by Norton AV.
For some protocols (among 20 available) it requires the address,
the local port and the remote port.
How can I get around the problem? To avoid the pop-up AGS2 I can only work with Net Off
Best regards
  β€’
Pages (6): « Previous 1 2 3 4 5 6 Next »
  Autodesk Universal Patch 2020-2024 All Products Dell_Brett 2 15,181 10-04-2023, 07:10 AM
  Autodesk Robot Structural Analysis Professional 2024 (x64) Multilanguage TAFATNEB 1 12,651 04-16-2023, 09:52 AM
  Autodesk Structural Bridge Design 2024-32bit X86.ISO TAFATNEB 0 4,604 04-13-2023, 07:37 AM
  Autodesk Navisworks Simulate 2024 (x64) Multilanguage TAFATNEB 1 5,194 04-03-2023, 04:08 PM
Last Post: cargadory2k
