Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 549.6: Guide to Design and Construction of Externally Bonded Fabric-Reinforce
Likes: 8,311 in 1,373 posts
Given Likes: 94
08-15-2021, 08:59 AM (This post was last modified: 05-09-2023, 12:20 PM by Administrator.)
ACI 549-6R-20: Guide to Design and Construction of Externally Bonded Fabric-Reinforced Cementitious Matrix (FRCM) and Steel-Reinforced Grout (SRG) Systems for Repair and Strengthening Masonry
Size: 26 MB | Format: PDF | Quality: Original preprint | Publisher: ACI | Year: 2020 | pages: 166 | ISBN: 978-1-64195-120-3
[Image: 53273471383467376049.png]
This guide addresses the use of externally bonded (EB) fabricreinforced cementitious matrix (FRCM) and steel-reinforced grout (SRG) systems for repair and strengthening of masonry structures. FRCM and SRG are composite materials composed of a reinforcement in the form of open fabric bonded on the masonry surface through an inorganic matrix. In particular, the structural reinforcement for FRCM consists of an open grid fabric of continuous fibers made of carbon, alkali-resistant (AR) glass, polyparaphenylene benzobisoxazole (PBO), aramid, or basalt fibers, while SRG systems use steel cords of twisted wires arranged to form a unidirectional fabric. The matrixes are typically based on combinations of portland cement, silica fume, and fly ash as the binder (cement-based), or on natural hydraulic lime (lime-based), or even on geopolymer (geopolymer-based). FRCM and SRG systems represent an alternative to traditional strengthening techniques such as steel tie rods, section enlargement, or even fiber-reinforced polymer (FRP) systems. FRCM and SRG systems can be used for various structural purposesβ€”for example, they are used to: 1) increase the loadbearing capacity of structural members; 2) improve the seismic capacity of buildings; 3) counteract specific incipient or already developed damage; 4) limit opening of cracks; and 5) strengthen local weaknesses. Based on experimental research, analytical work, and field applications, this guide provides the recommendations for the design and structural evaluation of FRCM and SRG systems according to both American and European existing regulations and guidelines.
[-] The following 21 users Like poolmand's post:21 users Like poolmand's post
  β€’ blaze, Administrator , cace-01, kowheng, civilfafa, Dell_Brett, temp1366, Wijono, oanm2000, malc, simanta, vvvv, levanduy, zrilek, Umer.Aleem, jonygut, mgdario, Hengki, avge, mohamz, spat
Given Likes: 94
05-09-2023, 12:39 PM
  β€’ babakfeyzi, jcbv, PinkPant, Dell_Brett
  ACI 549.4: Guide to Design and Construction of Externally Bonded Fabric-Reinforced Ce poolmand 0 1,751 01-23-2024, 12:10 PM
  ACI 440.2: Guide for the Design and Construction of Externally Bonded FRP Systems ir_71 5 5,913 01-17-2024, 07:34 AM
  ACI 526: Guide for Design and Construction with Autoclaved Aerated Concrete Panels poolmand 0 2,000 01-17-2024, 07:27 AM
  ACI 440.7: Guide for Design & Construction of Externally Bonded FRP Systems for Stren ir_71 1 3,145 11-06-2023, 05:40 AM
  ACI 440.1: Guide for the Design and Construction of Structural Concrete Reinforced wi poolmand 0 1,894 05-08-2023, 01:39 PM
  ACI 371: Guide for Analysis, Design, & Construction of Elevated Concrete & Composite lisine 3 4,193 05-08-2023, 12:20 PM
  ACI 222.3: Guide to Design and Construction Practices to Mitigate Corrosion of R Mohammad6299 1 2,425 05-07-2023, 10:18 AM
