Civil Engineering Association Software Software Product Autodesk Products Autodesk Products 2023
 rami1976
User ID: 34597
Threads: 341
Likes: 9,524 in 1,138 posts
Given Likes: 1388
#31
08-15-2022, 08:06 PM
Factory Design Utilities 2023
NOTE:
See post #6 and #7 in page 1 for UNIVERSAL MEDICINE for all Autodesk 2023 products
[-] The following 1 user Likes rami1976's post:1 user Likes rami1976's post
  • Dell_Brett
 rami1976
User ID: 34597
Threads: 341
Given Likes: 1388
#32
08-16-2022, 06:13 AM
CAMplete 2023
TruePath
TurnMill
NOTE:
  • Dell_Brett
 alireza55
User ID: 176296
Threads: 22
Likes: 102 in 52 posts
Given Likes: 0
#33
08-22-2022, 07:29 AM
Mechanical Addon for Autodesk AutoCAD 2023.0.1 (x64)
[Image: 12477415576293686963.jpg]
Abstract: Other software on the AutoCAD platform is the Autodesk AutoCAD Mechanical program, which, as its name implies, is not limited to the usual features of AutoCAD software, including tools and additional tools for designing mechanical components. This software provides a comprehensive library of components as well as complete tools based on mechanical design standards.
What is an addon?
Many users of "vertical" AutoCAD products have noticed that recently, any AutoCAD product with advanced functionality consists, in fact, of AutoCAD as a base and add-on for Mechanical, Electrical, Architecture, etc. Alas, the developers, as before, post only full-format distributions ... That is, if you want to get your hands on Mechanical and Architecture, you have to download two huge packages, most of the content of which duplicates each other. In this regard, I decided to start releasing distributions of a new type containing only an add-on. Now, to install all the same Mechanical and Architecture, you will need to download basic AutoCAD and two small add-ons. Less download, more compact storage - this is the main idea of assemblies of this format!
Features and Features of Autodesk AutoCAD Mechanical
- Designing and modeling of mechanical parts
- Creates the exact dimensions of the mechanical models intelligently
- Has a library of more than 700,000 standard parts and features with the ability to add custom parts to it
- Ability to update and align parts to the latest standards
- Synergy for mechanical engineering
- Ability to analyze the layout
- Getting ready to draft, document, annotate, report and share projects.
- Has a content browser section to quickly find the content you need
- New support for 3D CAD models
- Co-ordinates with other AutoCAD suite programs as well as current mechanical design software
System Requirements
- OS:Microsoft Windows 10 (64-bit only) (version 1803 or higher)
- CPU:Basic:2.5–2.9 GHz processor / Recommended:3+ GHz processorMultiple processors:Supported by the application
- RAM:Basic:8 GB / Recommended:16 GB
- Display Resolution:Conventional Displays:1920 x 1080 with True Color / High Resolution & 4K Displays:Resolutions up to 3840 x 2160 supported on Windows 10, 64-bit systems (with capable display card)
- Disk space:6.0 GB
What's New
- The assembly is based on the original Russian and English distributions combined into a single package, from which everything that is not directly related to the installation of the Mechanical add-on has been removed.
- For a modern installer, a solution was developed and implemented for choosing the interface language of the installed program.
- The interface language of the installer itself is set based on the OS interface language.
- Since the so-called "classic interface" was missing in Mechanical by default, I considered it possible to restore it for the afflicted.
- AutoCAD Mechanical 2023.0.1 Update has been integrated into the installation package.
- Updated Autodesk On-Demand Install Service from version 1.27.0.558 to version 1.30.0.517.
- Installer updated from version 1.27.0.4 to version 1.30.0.7.
- The assembly does not include medicine. The cure is included in my build of AutoCAD 2023, on top of which it is recommended to install this addon.
Windows (x64) | Languages: English, Russian
 alireza55
User ID: 176296
Threads: 22
Given Likes: 0
#34
08-22-2022, 07:33 AM
Architecture Addon for Autodesk AutoCAD 2023.0.1 (x64)
[Image: 39241239746083007365.jpg]
Abstract: AutoCAD Architecture software is AutoCAD software for architects. Architectural drafting and documentation is more efficient with the software’s intuitive environment and specialized building design tools built specifically for architects.
What is an addon?
Facilities and software features Autodesk AutoCAD Architecture
- the familiar AutoCAD environment, thus enabling a fast learning
- drawing two-dimensional design and drawing three-dimensional architectural work at the same time
- has an extensive library of building components such as walls, doors, windows and ...
- The ability to remove or add a new component designs Bhrvzshdn Overview
- precision in the design and planning
- Speed up design allows quick restoration plan
- Design of ceilings new standards
- creation of full color as close to the real view
- Mapping the floor using different materials
- Ability to Khrvjygrftn for common software design
System Requirements
- Multiple processors:Supported by the application
- RAM:Basic:8 GB/Recommended:16 GB
- Display Resolution:Conventional Displays:1920 x 1080 with True Color / High Resolution & 4K Displays:Resolutions up to 3840 x 2160 - supported on Windows 10, 64-bit systems (with capable display card)
- Disk space:Disk Space:8.0 GB
Additional Requirements
-Disk Space: 8GB
-.NET Framework Version 4.7.2
-MS SQL Server (Express, Standard, or Enterprise edition) 2008 SP1 or newer
What's New
- The assembly is based on the original Russian and English distributions combined into a single package, from which everything that is not directly related to the installation of the Architecture add-on has been removed.
- AutoCAD Architecture 2023.0.1 Update has been integrated into the installation package.
[-] The following 1 user Likes alireza55's post:1 user Likes alireza55's post
  • Williams
 alireza55
User ID: 176296
Threads: 22
Given Likes: 0
#35
08-22-2022, 07:39 AM (This post was last modified: 08-22-2022, 10:16 AM by Dell_Brett.)
MEP 3D Addon for Autodesk AutoCAD 2023.0.1 (x64)
[Image: 57223150464398961729.jpg]
Abstract: Autodesk AutoCAD MEP is a new Autodesk product developed on the basis of AutoCAD software, which provides specialized facilities for designing construction projects. MEP stands for the three words M echanical, ie mechanical, E lectrical, meaning electrical and P lumbing, which means plumbing. Therefore, it is possible to design a variety of equipment in the building, both electrical and mechanical, as well as the design of the pipe path in this software.
What is an addon?
Features and features of Autodesk AutoCAD MEP software
- The familiar interface of AutoCAD software with the specialized tools required
- Designing and precise drawing of various types of construction equipment such as power grid, ventilation, lift, fire fighting equipment, pipe path
- Ability to automatically calculate the size of spaces
- Supports IFC data (stands for Industry Foundation Classes, meaning fundamental industry classes).
- The complete integration of other AutoCAD products, such as AutoCAD Architecture, Autocad Mechanical and Autocad Electrical, etc.
- The use of DWG technology and format for easy design exchange with high software
System Requirements
- Disk space:Disk Space: 12GB
What's New
- The assembly is based on the original Russian and English distributions combined into a single package, from which everything that is not directly related to the installation of the MEP add-on has been removed.
- Added the ability to opt out of installing the AutoCAD MEP DIALux 2023 module to the installation package.
- AutoCAD MEP 2023.0.1 Update has been integrated into the installation package.
 rami1976
User ID: 34597
Threads: 341
Given Likes: 1388
#36
09-13-2022, 05:23 PM (This post was last modified: 09-13-2022, 05:26 PM by rami1976.)
AutoCAD Civil 3D 2023.1 Update Only
New Magnitude NLM
  • Dell_Brett, zrilek, chrono146, Vatsalbu89, Civilized
 gangi
Italy
User ID: 86807
Likes: 2 in 2 posts
Given Likes: 4
#37
02-14-2023, 07:51 AM
Can you post other link for #6 cure? it's ok also for revit?
Thanks
Threads: 750
Likes: 8,270 in 1,355 posts
Given Likes: 88
#38
02-28-2023, 07:41 AM (This post was last modified: 02-28-2023, 07:55 AM by poolmand.)
Autodesk AutoCAD Plant 3D 2023
AutoCAD Plant 3D 2023 + Offline update 2023.0.1 + Offline Help + Object Enabler + Crack
  • Dell_Brett, Administrator , PinkPant
Pages (4): « Previous 1 2 3 4
  Autodesk 2010 Products Keygen cod-X 6 22,427 03-12-2025, 09:49 AM
  Autodesk Products 2012 x-force keygen for x32 systems BennyP 7 18,420 03-07-2025, 10:37 AM
  Autodesk Universal Patch 2020-2024 All Products Dell_Brett 2 14,966 10-04-2023, 07:10 AM
  Autodesk 2022 Products Keygen + License Server poolmand 0 9,236 10-18-2021, 08:44 AM
  Autodesk x64 2019 Products Network License BennyP 1 6,375 09-24-2020, 06:37 AM
Last Post: Vatsalbu89
  Autodesk 2021 Products Keygen + License Server pezhmankhan 1 9,119 09-14-2020, 06:19 PM
  Autodesk Fabrication Products 2016 BennyP 1 6,725 04-09-2016, 02:59 PM
Last Post: Zacha01
