Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 544.11: Measuring Shrinkage, Creep, and Transport Properties of Fiber-Rein
Likes: 8,311 in 1,373 posts
Given Likes: 93
08-16-2022, 04:24 AM (This post was last modified: 05-02-2023, 11:30 AM by Administrator.)
ACI PRC-544.11-22: Measuring Shrinkage, Creep, and Transport Properties of Fiber-Reinforced Concreteβ€”Report
Author(s)/Editor(s): ACI Committee 544 | Size: 4.94 MB| Format: PDF| Quality: Original preprint| Publisher: ACI| Year: 2022| pages: 19 | ISBN: 9781641951814
Fiber-reinforced concrete (FRC) has become a viable choice for many designers and builders for the unique properties and advantages it provides. From slabs-on-ground to underground structures, the use of FRC has been expanding in concrete construction. This growth of applications has created the need to review the existing test methods for FRC and, where necessary, develop new ones. Two reports (ACI 544.2R and ACI 544.9R) have already been published regarding testing fresh properties and mechanical properties of FRC, respectively. This report is the third and final report on testing FRC for its durability properties, including shrinkage, creep, and permeability. Several standard and nonstandard test methods are presented in this report to represent some of the knowledge in this area.
creep; durability; fiber-reinforced concrete; shrinkage; testing; transporting.
[-] The following 10 users Like poolmand's post:10 users Like poolmand's post
  β€’ Administrator , PinkPant, temp1366, jcbv, milova, mgdario, oanm2000, Dell_Brett, malc, kowheng
  ACI 209.2: Guide for Modeling and Calculating Shrinkage and Creep in Harde... portal61 2 3,840 05-09-2023, 10:51 AM
  ACI 223: Guide for the Use of Shrinkage-Compensating Concrete ir_71 2 3,816 05-09-2023, 10:45 AM
  ACI 304.6: Guide for Use of Volumetric-Measuring and Continuous-Mixing Concrete Equip lisine 2 2,482 05-08-2023, 10:48 AM
  ACI 544.5: Report on the Physical Properties and Durability of Fiber-Reinforced Co ir_71 2 2,976 05-03-2023, 06:11 AM
  ACI 544.2R: Report on the Measurement of Fresh State Properties and Fiber Dispers poolmand 1 1,832 02-27-2023, 08:41 AM
  ACI 223: Shrinkage-Compensating Concrete - Guide poolmand 0 1,347 12-07-2021, 10:39 AM
  ACI 304.3: Heavyweight Concrete: Measuring, Mixing, Transporting and Placing poolmand 0 1,430 12-01-2021, 05:10 AM
