Civil Engineering Association eBooks Structural Books Steel Steel Plate Shear Walls with Gravity Load: Theory and Design
 carolinandra
Colombia
User ID: 12281
Threads: 110
Likes: 2,885 in 157 posts
Given Likes: 1333
02-14-2022, 12:55 PM
Steel Plate Shear Walls with Gravity Load: Theory and Design Steel Plate Shear Walls with Gravity Load: Theory and Design
Author(s)/Editor(s): Yang Lv | Size: 8.4 MB| Format: PDF| Quality: Original preprint| Publisher: Springer| Year: 2022| pages: 198 | ISBN: ISBN-13: 978-9811686931 ISBN-10: 9811686939
[Image: 49204005606239161735.png]
This book is written by subject experts based on the recent research results in steel plate shear walls considering the gravity load effect. It establishes a vertical stress distribution of the walls under compression and in-plane bending load and an inclination angle of the tensile field strip. The stress throughout the inclined tensile strip, as we consider the effect of the vertical stress distribution, is determined using the von Mises yield criterion. The shear strength is calculated by integrating the shear stress along the width. The proposed theoretical model is verified by tests and numerical simulations. Researchers, scientists and engineers in the field of structural engineering can benefit from the book. As such, this book provides valuable knowledge, useful methods, and practical algorithms that can be considered in practical design of building structures adopting a steel shear wall system.
[-] The following 19 users Like carolinandra's post:19 users Like carolinandra's post
  â€¢ vvvv, CAMSECT, caifan, cheosmith, Dell_Brett, oanm2000, babakfeyzi, milova, zrilek, jcbv, subin91, blaze, cace-01, mgdario, malc, temp1366, lisine, hodzicemir, kowheng
Away  bridgeengineer
Poland
User ID: 93214
Threads: 47
Likes: 1,023 in 110 posts
Given Likes: 4769
12-25-2022, 03:07 PM
please reupload
thanks
  â€¢
Likes: 8,311 in 1,373 posts
Given Likes: 94
12-26-2022, 10:45 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
  â€¢ bridgeengineer, zrilek, Dell_Brett, mgdario, PinkPant, rami1976, Andrew seah, hodzicemir, sodapas
  Tubular Steel Structures Theory and Design-2nd edition david-smith 3 5,379 11-27-2014, 04:20 PM
Last Post: apocalipse
  Advanced Analysis of Steel Frames Theory, Software, and Applications abudabeeja 3 4,801 11-20-2014, 03:18 PM
  Fatigue Life of Steel Base Plate to Pole Connections for Traffic Structures mahyarov 0 1,725 11-13-2012, 10:24 AM
Last Post: mahyarov
  Eurocode Load Combinations for Steel Structures miquan 1 2,430 08-14-2012, 12:07 AM
Last Post: 3fan
  Seismic Behavior and Design of Steel Shear Walls by: Abolhassan Astaneh-Asl babak 1 2,953 01-10-2012, 07:25 AM
Last Post: Grunf
