Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 197-1:2000 + A1:2004 Cement
10-28-2010, 05:04 AM
EN 197-1:2000/A1:2004 Cement - Part 1: Composition, specifications and conformity criteria for common cements
[Image: 46416565509882989764.jpg]
EN 197-1 defines and gives the specifications of 27 distinct common cement products and their
constituents. The definition of each cement includes the proportions in which the constituents are
to be combined to produce these distinct products in a range of six strength classes. The definition
also includes requirements the constituents have to meet and the mechanical, physical and
chemical !including, where appropriate, heat of hydration requirements" of the 27 products
and strength classes. EN 197-1 also states the conformity criteria and the related rules. Necessary
durability requirements are also given.
NOTE 1: In addition to the specified requirements, an exchange of additional information between the cement
manufacturer and user may be helpful. The procedures for such an exchange are not within the scope
of EN 197-1 but should be dealt with in accordance with national standards or regulations or may be
agreed between the parties concerned.
NOTE 2: The word β€œcement” in EN 197-1 is used to refer only to common cements unless otherwise specified.
:JC_cheers:
  β€’ kowheng, toa011, vvvv, roaming79, oanm2000, Adam Smith, Dell_Brett, civiea_civiea, dexter238, zrilek, rigid_joint
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
12-01-2011, 12:05 AM
As per request, Then I upload this standard.
BS EN 197-1:2011 Cement. Composition, specifications and conformity criteria for common cements
Size: 1.4 MB | Format: PDF | Publisher: BSI | Year: 30 September 2011 | pages: 50 | ISBN: 978 0 580 76786 9
[Image: 80154619717649756746.png]
This European Standard defines and gives the specifications of 27 distinct common cements, 7 sulfate resisting common cements as well as 3 distinct low early strength blast furnace cements and 2 sulfate resisting low early strength blast furnace cements and their constituents.
The definition of each cement includes the proportions in which the constituents are to be combined to produce these distinct products in a range of nine strength classes.
The definition also includes requirements which the constituents have to meet. It also includes mechanical, physical, and chemical requirements. Furthermore, this standard states the conformity criteria and the related rules. Necessary durability requirements are also given.
Contents for BS EN 197-1:2011 includes:
- Scope
- Normative references
- Terms and definitions
- Cement
- Constituents
- General
- Main constituents
- Portland cement clinker (K)
- Granulated blast furnace slag (S)
- Pozzolanic materials (P, Q)
- Fly ashes (V, W)
- Burnt shale (T)
- Limestone (L, LL)
- Silica fume (D)
- Minor additional constituents
- Calcium sulphate
- Additives
- Composition and notation
- Composition and notation of common cements
- Composition and notation of sulfate resisting common cements (SR-Cements)
- Composition and notation of low early strength common cements
- Mechanical, physical, chemical and durability requirements
- Mechanical requirements
- Standard strength
- Early strength
- Physical requirements
- Initial setting time
- Soundness
- Heat of hydration
- Chemical requirements
- Durability requirements
- General
- Sulfate resistance
- Standard designation
- Conformity criteria
- General requirements
- Conformity criteria for mechanical, physical and chemical properties and evaluation procedure
- General
- Statistical conformity criteria
- Single result conformity criteria
- Conformity criteria for cement composition
- Conformity criteria for properties of the cement constituents
This British Standard is the UK implementation of EN 197-1:2011.
It supersedes BS EN 197-1:2000 and BS EN 197-4:2004 which are withdrawn.
Moderator maybe can change the title this Thread to EN 197-1 Cement
[-] The following 11 users Like mybest's post:11 users Like mybest's post
  β€’ kowheng, Dell_Brett, malc, ir_71, Jackass, vpmohammed, zrilek, st77bel, [bds], miquan, i_kabir
 mybest
Indonesia
User ID: 32155
Threads: 265
Given Likes: 686
12-01-2011, 06:05 AM
BS EN 197-2:2000 Cement. Conformity evaluation
Size: 276 KB | Format: PDF | Publisher: BSI | Year: 15 September 2000 | pages: 30 | ISBN: 0 580 36455 0
[Image: 83198433752231669035.png]
Specifies the scheme for the evaluation of the conformity of cements to their corresponding product specifications.
  β€’ kowheng, Jackass, vvvv, Dell_Brett, monter, zrilek, st77bel, [bds], miquan, i_kabir, visu
 CAMSECT
Cambodia
User ID: 175572
Threads: 1
Likes: 2 in 2 posts
Given Likes: 402
02-13-2022, 10:30 AM
please new link
  β€’
Likes: 8,312 in 1,373 posts
Given Likes: 94
02-13-2022, 11:26 AM
Size: 4.82 MB | Format: PDF | Publisher: BSI | Year: 30 September 2011 | pages: 50 | ISBN: 978 0 580 76786 9
  β€’ Dell_Brett, zrilek, CAMSECT, Administrator , oanm2000
Given Likes: 94
02-13-2022, 11:37 AM
BS EN 197-2:2000 & 2020 Cement. Conformity evaluation
Size: 3.13 MB | Format: PDF | Publisher: BSI | Year: 15 September 2000 | pages: 30 | ISBN: 0 580 36455 0
  β€’ zrilek, CAMSECT, babakfeyzi, Dell_Brett, kowheng, oanm2000
