Civil Engineering Association Software Software Product Bentley Products Bentley ProStructures CONNECT Edition Update 5.2 (10.05.02.50) x64
Likes: 8,311 in 1,373 posts
Given Likes: 94
10-19-2021, 12:01 PM
[Image: 94166158579086631832.png]
[Image: 19734495577910766870.jpg]
ProStructures CONNECT Edition update 5.2
ProStructures easily allows structural engineers, detailers, and fabricators to create 3D models for both concrete and steel. ProStructures provides automatic creation of documentation, details, and schedules. The open working environment and programming interface supports standardization of the program.
Capabilities:
- Design to international standards
Extend the reach of your business practice and take advantage of global design opportunities by using a wide range of international standards and specifications in our design products. Complete your designs with confidence thanks to extensive support of international standards.
- Detail and schedule concrete reinforcing
Produce rebar placing drawings, including sections, plans, details, bar bending schedules, material take-offs and beam/column/footing schedules, all based on the 3D model. All schedules and drawings can be customized to adhere to your company’s standards for concrete projects.
- Model parametric structures
Model structural members such as beams, columns, braces, steel connections, footings, foundations, and rebar. Apply steel connections between beams and columns, updating size changes automatically. Member types are also parametric for assemblies such as stairs, ladders, and handrails.
- Model reinforced concrete
Model reinforced concrete shapes such as concrete beams, columns, slabs, walls, spread footings, and continuous footings, all with parametric behavior. Changes to the concrete shape cause the rebar to adjust automatically. Model complex reinforced concrete shapes, including curves, sloping, or non-orthogonal shapes using intuitive commands.
- Produce steel fabrication drawings
Produce drawings for every steel shape, connection, and plate-work from the 3D model. Easily create comprehensive single-part drawings including dimensions, notes, labels, and part lists. Customize drawings to adhere to your company’s standards for all your structural steel projects. Any out-of-date drawings are automatically updated based on changes to the 3D model.
- Produce structural concrete details
Produce rebar placing drawings, including sections, plans and details from the 3D model. Quickly create details of reinforcing, including automated rebar labels, dimensions, and notes. Customize all drawings to adhere to your company’s standards for all your reinforced concrete projects. Automatically update drawings based on changes to the 3D model.
- Produce structural construction documentation
Produce construction documentation such as plans, sections, and details, all automatically linked to the 3D model. Changes made to the 3D model are automatically updated in the drawings. Easily manage changes and revisions to the model with automated flags on drawings that need to be reissued.
- Produce structural design documentation
Generate structural design documents including necessary plans and elevations that are used to convey the design intent. Changes made to the 3D model are automatically updated in the documentation.
- Produce structural details
Produce detailed 2D drawings directly from design results established in the structural model. Customize the style and format of the drawings using settings offered within the software.
- Share structural models
Transfer structural model geometry and design results from one application to another and synchronize changes over time. Quickly share the structural model, drawings, and information with the entire team for review.
- Track and rollback structural design changes
Manage design changes made to the 3D model, tracking revisions with optional descriptions and timestamps. At any time during the project, selected changes can be rolled back or undone. Explore multiple design scenarios, as well as recover quickly from modeling errors.
- Utilize international section profiles
Complete your structural model using a vast array of international section profile databases, which are included at no extra charge. Take advantage of global design opportunities around the world.
[Image: homepage.png]
[-] The following 8 users Like poolmand's post:8 users Like poolmand's post
  β€’ Administrator , vvvv, cace-01, Dell_Brett, PinkPant, oanm2000, spat, erkeym1
  Bentley ProStructures 2024 poolmand 2 4,447 02-01-2025, 10:44 AM
  STAAD.Pro CONNECT Edition Update 3 (21.03.00.146) RajaK 7 13,341 07-27-2024, 03:40 AM
  Bentley MicroStation CONNECT Edition 2023 poolmand 2 6,519 10-08-2023, 12:24 PM
  Bentley STAAD.Pro CONNECT V23 poolmand 0 6,376 10-02-2023, 09:01 AM
  Bentley STAAD.Pro CONNECT Edition V22 kirankumarklk 12 23,081 07-05-2023, 07:52 AM
Last Post: Arigato
  Bentley.RCDC.Connect.Edition.11.02.00.200 kirankumarklk 0 5,041 04-02-2022, 11:14 AM
Last Post: kirankumarklk
  RCDC FE Connect Edition V4 Update 1 RajaK 1 7,049 03-28-2022, 06:28 AM
