Civil Engineering Association Software Software Product Autodesk Products Autodesk AutoCAD Civil 3D 2022
Threads: 760
Likes: 8,277 in 1,357 posts
Given Likes: 91
10-06-2021, 12:50 PM (This post was last modified: 10-09-2021, 06:02 AM by Administrator. Edit Reason: N/A )
Autodesk AutoCAD Civil 3D 2022.1
Autodesk Civil 3Dยฎ civil engineering design software supports BIM (Building Information Modeling) with integrated features to improve drafting, design, and construction documentation. Civil 3D features support a variety of civil infrastructure projects including rail, roads and highways, land development, airports, drainage, storm and sanitary, and civil structures. Improve your infrastructure design with continuous software enhancements. Recent updates include design automation with Dynamo for Civil 3D and a more intuitive interface.
- Dynamo for Civil 3D
Use Dynamo for programming and design automation. Define scripts and routines in a visual environment to design and expedite workflows.
- Storm and sanitary analysis
Set individual tailwater conditions for each designed storm, use dimensionless Hydrographs per sub-basin, and use new storage chambers by ADS.
- Gravity network analysis
Use the updated Analyze Gravity Network dialog to analyze a pipe network and apply the results.
- User interface
Discover the updated interface, optimized for display on high-resolution monitors. Use more intuitive command definitions to easily interact with Civil 3D.
๐Ÿ‘‰ CLICK HERE ๐Ÿ‘ˆ
[Image: comments.png]
System requirements for Civil 3D 2022
Operating System
- 64-bit Microsoftยฎ Windowsยฎ 10
- 64-bit Microsoft Windows 8.1
See Autodeskโ€™s Product Support Lifecycle for support information.
Processor:
Minimum: 2.5โ€“2.9 GHz processor
Recommended: 3+ GHz processor
Memory: 16 GB
Display Resolution: Conventional Displays: 1920 x 1080 with True Color
High Resolution & 4K Displays: Resolutions up to 3840 x 2160 supported on Windows 10, 64 bit systems (with capable display card)
Display Card:
Minimum: 1 GB GPU with 29 GB/s Bandwidth and DirectX 11 compliant
Recommended: 4 GB GPU with 106 GB/s Bandwidth and DirectX 11 compliant
Disk Space: 16 GB
Pointing Device: MS-Mouse compliant
File Format Changes: No DWG or Civil 3D Object format changesยน.
ยนBridge and piping features added in 2021 may display as a proxy objects in prior versions.
.NET Framework: .NET Framework Version 4.8
Additional Requirements for large datasets, point clouds, and 3D modeling
Memory: 16 GB RAM or more
Disk Space: 6 GB free hard disk available, not including installation requirements
Display Card: 1920 x 1080 or greater True Color video display adapter; 128 MB VRAM or greater; Pixel Shader 3.0 or greater; Direct3Dยฎ capable workstation class graphics card.
  โ€ข cheosmith, Dell_Brett, rami1976, PinkPant, Administrator , oanm2000
Threads: 760
Given Likes: 91
01-09-2022, 06:55 AM (This post was last modified: 01-09-2022, 06:57 AM by Administrator.)
Autodesk AutoCAD Civil 3D UPDATE to 2022.1.2
  โ€ข Dell_Brett, Administrator , oanm2000, yehiaabdelkarim
 pilitro
User ID: 35528
Likes: 2 in 1 posts
Given Likes: 0
03-13-2022, 03:04 PM
new mirror please, links are down.
[-] The following 2 users Like pilitro's post:2 users Like pilitro's post
  โ€ข KG01, yehiaabdelkarim
  AutoRebar for Autodesk AutoCAD poolmand 1 12,516 08-18-2025, 09:58 AM
  Autodesk AutoCAD Civil 3D 2025 poolmand 2 6,024 12-02-2024, 01:09 PM
  X-Force universal FlexNet patch to ANY Autodesk 2022 software pezhmankhan 5 33,881 02-05-2024, 01:50 PM
Last Post: spybot
  Autodesk AutoCAD Plant 3D 2022 (x64) Pre-Cracked BennyP 1 10,654 10-27-2023, 04:10 PM
Last Post: Dalvisahi014
  Civil Survey Applications ( ex . Solutions ) Civil Site Design v24.0 for Autodesk Civ poolmand 1 5,318 05-06-2023, 02:32 PM
Last Post: Mobadi
  Autodesk 3DS MAX 2022 (x64) Multilanguage BennyP 2 8,702 08-27-2022, 02:21 PM
Last Post: alireza55
  Autodesk AutoCAD 2022 (x64) BennyP 5 13,853 03-29-2022, 11:33 AM
Last Post: Arigato
