Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering Statistics of SDF-system estimate of roof displacement for pushover analysis of build
 ynopum
Burundi
User ID: 2733
Threads: 24
Likes: 2,399 in 365 posts
Given Likes: 155
11-03-2009, 09:29 PM (This post was last modified: 01-03-2012, 07:54 PM by usman.)
Statistics of SDF-system estimate of roof displacement for pushover analysis of buildings
Chopra, Anil K.; Goel, Rakesh K.; Chintanapakdee, Chatpan
PEER-2001/16, Pacific Earthquake Engineering Research Center, University of California, Berkeley, 2001-12, 58 pages (400/P33/2001-16)
This report investigates the basic premise that the roof displacement of a multistory building can be determined from the deformation of a SDF system. For this purpose, the response of both systems is determined rigorously by nonlinear response history analysis, without introducing any of the approximations underlying the simplified methods for estimating the deformation of a SDF system (see, e.g., FEMA-273 or ATC-40 guidelines). The statistics of the SDF-system estimate of roof displacement are presented for a variety of building frames and six SAC buildings subjected to ground motion ensembles. Two sets of structural systems and ground motions are considered. The first set is generic one-bay frames of six different heights: 3, 6, 9, 12, 15, and 18 stories designed for ductility factor mu = 1, 1.5, 2, 4, and 6 subjected to 20 large-magnitude, small-distance records. The second set is six "SAC" buildings--9- and 20-story model buildings designed according to Los Angeles, Seattle, and Boston codes--subjected to 20 ground motion records representing 2% probability of exceedance in 50 years. The statistics of two roof-displacement, mu subscript r, ratios are presented. The data presented include histograms of the 20 values, range of values, median value, and dispersion measure. These data for generic frames indicate that the first-"mode" SDF system overestimates the median roof displacement for systems subjected to large ductility demand mu, but underestimates for small mu. Similar data for SAC buildings demonstrate that the bias and dispersion in the SDF estimate of roof displacement increases when P-delta effects (due to gravity loads) are included. The SDF estimate of roof displacement due to individual ground motions can be alarmingly small (as low as 0.312 to 0.817 of the "exact" value for the six SAC buildings) or surprisingly large (as large as 1.45 to 2.15 of the exact value for Seattle and Los Angeles buildings), especially when P-delta effects are included. The situation is worse than indicated by these data because they do not include several cases where the first-"mode" SDF system collapsed but the building as a whole did not. This large discrepancy arises because for individual ground motions the SDF system may underestimate or overestimate the yielding-induced permanent drift in the "exact" response determined by nonlinear RHA. While this discrepancy is not improved significantly by including higher "mode" contributions, the MPA procedure has the advantage of reducing the dispersion in the roof displacement and the underestimation of the median roof displacement for elastic or nearly elastic cases at the expense of increasing slightly the overestimate of roof displacement of buildings responding far into the inelastic range.
[Image: ikue6pu2osbinw4idkd.png]
[-] The following 22 users Like ynopum's post:22 users Like ynopum's post
  β€’ preceptor, Ultra Zone, kowheng, niki102, verongskey, ruaumoko, ashcivilea, aflv, jcoronellr, cmorpar, Galileo, cve_jule, blackjack, cristi, nguyennam, civilgr, TAFATNEB, zainseiya, lisine, DamirDz, giga, Dell_Brett
Threads: 57
06-24-2012, 07:11 AM
PDF 1.35 MB
[-] The following 13 users Like kowheng's post:13 users Like kowheng's post
  β€’ malc, melkat, david-smith, gulilero, zrilek, seriousboy, mgdario, draluka, giga, Jackass, sodapas, Dell_Brett, rezart
  Dynamic Analysis of Skeletal Structures Force and Displacement Methods and Iterative sabooryan 4 3,273 04-15-2022, 02:00 AM
Last Post: sandeepb
  Procedure to Perform Pushover Analysis (for RC Structures with SAP2000) Sumatra 2 4,612 03-24-2017, 03:55 PM
  A Modal Pushover Analysis Procedure to Estimate Seismic Demands for Buldings Ultra Zone 5 6,131 07-29-2012, 10:47 AM
Last Post: shadabg
  Limits of Applicability of Conventional and Adaptive Pushover Analysis for Seismic Re Veggeta 2 2,982 03-22-2011, 07:25 AM
  SAP2000 Detailed Tutorial Including Pushover Analysis Ultra Zone 1 4,302 09-20-2009, 03:33 AM
Last Post: timosiβ„’
  Statistics of SDF System Estimate of Roof Displacement for Pushover Analysis of Build Ultra Zone 0 2,405 09-17-2009, 08:01 PM
Last Post: Ultra Zone
