Civil Engineering Association Software Software Product Non Engineering Software Wondershare UniConverter 12.5.5.12
Threads: 1,128
03-02-2021, 07:33 AM
You can convert 2B video to 3D, directly convert DVD video to various popular formats, you can also burn DVD media, there is support for extracting audio tracks from video files, if you need to trim a video, this is easy to do (let's say there are black bars), Wondershare Video Converter will also allow you to fine-tune the output video, you can add various effects (for example, a watermark, fading, and so on), the program can also split a large file into small ones and vice versa, merge them, there is a function for capturing an image when watching a video. Wondershare Video Converter supports working with profiles, you can create a specific one, for example, to convert a video to the desired format, set all the parameters in advance, and then just load it, of course, you can convert in batch mode, if the file is protected by DRM technology, then it can be easily cracked.
  • kowheng, oanm2000
