Civil Engineering Association eBooks Codes, Manual & Handbook British Standards (BS) BS 8102:2009 - Code of practice for protection of below ground structures against wat
 Mohammad6299
User ID: 42302
Threads: 251
Likes: 7,913 in 854 posts
Given Likes: 4212
03-25-2015, 07:43 AM
BS 8102:2009 - Code of practice for protection of below ground structures against water from the ground
Size: 0.7 MB | Format: PDF | Quality: Original preprint | Publisher: BSI | Year: 2009 | Pages: 46 | ISBN: 9780580593994, 0580593991
[Image: 47466588316852621060.jpg]
BS 8102 gives recommendations and provides guidance on methods of dealing with and preventing the entry of water from surrounding ground into a structure below ground level.
It covers the use of:
a) Waterproofing barrier materials applied to the structure
b) Structurally integral watertight construction
c) Drained cavity construction.
It also covers the evaluation of groundwater conditions, risk assessment and options for drainage outside the structure. It applies to structures which extend below ground level and those on sloping sites.
BS 8102 does not give recommendations on the use of embedded heating in structures, floors and walls or for the special requirements in connection with the design and construction of cold stores.
BS 8102:2009 replaces BS 8102:1990, which is now withdrawn. This is a full revision of the standard, and includes the following changes:
a) A number of recent developments are addressed, which are important when specifying, designing and constructing below ground structures, including:
1) More deep construction in congested urban areas
2) An increase in the provision of residential basements
3) Development and use of new materials for waterproofing
b) A more detailed assessment is provided of the risks in below ground construction and how these might best be addressed.
[-] The following 25 users Like Mohammad6299's post:25 users Like Mohammad6299's post
  â€¢ avscorreia, cristi, Trishu999, geomahesh, vvvv, oanm2000, amindoxiti, Jackass, lisine, milova, zrilek, daywalker, eliseo.as, dinu69in, ssobhan, Dell_Brett, PinkPant, peixoto, malc, koohsari, monter, temp1366, kowheng, tuanpecc1, piseth
 temp1366
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 742
02-17-2021, 11:20 AM
[Image: password.png][/align]
[-] The following 15 users Like temp1366's post:15 users Like temp1366's post
  â€¢ babakfeyzi, civGr, rami1976, kowheng, levanduy, zrilek, agelos100, Dell_Brett, blaze, PinkPant, mohamz, tuanpecc1, Wijono, oanm2000, piseth
  BS 8006-1: Code of practice for Strengthened/reinforced soils and other fills ir_71 8 8,229 05-29-2024, 12:10 PM
  BS 5930:2015+A1:2020 - Code of practice for ground investigations concreteok 0 3,921 07-25-2023, 10:35 AM
Last Post: concreteok
  BS 6349-1: Maritime Structures: Code of Practice for General Criteria Gabemzaman 9 10,205 06-07-2023, 05:10 AM
Last Post: ersin
  BS 8102: Protection of below ground structures against water ingress poolmand 0 3,135 05-03-2023, 10:15 AM
  BS 8476: Code of practice for the safe use of concrete pumps ir_71 2 3,427 02-12-2022, 08:00 AM
  BS EN 14629:2007 Products and systems for the protection and repair of concrete structures ir_71 2 3,503 02-11-2022, 09:56 AM
Last Post: CAMSECT
  BS 5262:1991 Code of practice for External renderings ir_71 3 3,709 07-31-2021, 08:00 PM
Last Post: monter
