Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 223: Guide for the Use of Shrinkage-Compensating Concrete
05-27-2011, 04:20 PM (This post was last modified: 05-09-2023, 10:45 AM by Administrator.)
ACI 223 R-10 Guide for the Use of Shrinkage-Compensating Concrete
Author: ACI Committee 223 | Size: 1.2 MB | Format: PDF | Publisher: ACI | Year: 2010 | pages: 20
[Image: 55638602737182659599.jpg]
Recommendations of this guide include proportioning, mixing, placing, finishing, curing, and testing. Shrinkagecompensating concrete is produced using expansive cements or expansive component systems.
There have been significant changes and advances in the use of shrinkage-compensating concrete since it was first introduced into the market but, in some areas, the original practices remain the best current practice. Although many references used in this guide are over 10 years old, they remain a valid reference to today’s practice.
[-] The following 19 users Like ir_71's post:19 users Like ir_71's post
  β€’ kowheng, jcbv, Jackass, malc, hessi, vardan, Dell_Brett, st77bel, theanhpe, blaze, hzaheer, nhim4mat2006, mikecoo, araza023, kerenski_t, duazo2009, sivlad, nuttapolk, bigone
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
10-20-2020, 11:35 AM
ACI 223 R-10: Guide for the Use of Shrinkage-Compensating Concrete
[-] The following 10 users Like bigone's post:10 users Like bigone's post
  β€’ agelos100, jcbv, zrilek, PinkPant, Dell_Brett, blaze, mohamz, mgdario, oanm2000, spat
Likes: 8,311 in 1,373 posts
Given Likes: 94
ACI PRC-223-21: Shrinkage-Compensating Concrete - Guide
Author(s)/Editor(s): ACI Committee 223 | Size: 8.7 MB| Format: PDF| Quality: Scanner| Year: 2021| pages: 36 | ISBN: 9781641951647
[Image: 51330126088407644986.png]
Shrinkage-compensating concrete is used in construction to minimize drying-shrinkage cracking. Its characteristics are similar to those of portland-cement concrete. The materials, proportions, placement, and curing should ensure that expansion compensates for subsequent drying shrinkage.
This guide sets forth criteria and practices to ensure the development of expansive strain in concrete. In addition to a discussion of basic principles, methods and details are given covering structural design details and applications, concrete mixture proportioning, placement, finishing, and curing.
The materials, processes, quality control measures, and inspections described in this document should be tested, monitored, or performed as applicable only by individuals holding the appropriate ACI certifications or equivalent.
calcium cement; drying shrinkage; expansion cement; mixture proportions; restraints; shrinkage-compensating concrete; shrinkage cracking; slab-on-ground; structural design.
  β€’ jcbv, babakfeyzi, malc, PinkPant, Dell_Brett
  ACI 209.2: Guide for Modeling and Calculating Shrinkage and Creep in Harde... portal61 2 3,875 05-09-2023, 10:51 AM
  ACI 223: Shrinkage-Compensating Concrete - Guide poolmand 0 1,372 12-07-2021, 10:39 AM
