Civil Engineering Association Software Software Product Csi Products CSiXCAD CSiXCAD v18
CSiXCAD v18
 temp1366
User ID: 85519
Threads: 80
Likes: 1,544 in 165 posts
Given Likes: 742
09-22-2020, 01:50 PM (This post was last modified: 05-15-2024, 07:09 AM by poolmand.)
CSiXCAD 18 [No Medicince]
[Image: 52939070975304600445.jpg]
CSiXCAD, from Computers and Structures, Inc., is a plug-in for Autodesk® AutoCAD® and Bricsys® BricsCAD® that facilitates documenting in AutoCAD and BricsCAD the design of building stuctures analyzed in ETABS® or SAP2000® and keeps track of design revisions.
CSiXCAD maintains a complete BIM model in the CAD software and can generate:
Floor Plans
Elevations
3D Models
In addition, with models designed in ETABS, CSiXCAD can generate:
Beam and Column Schedules
Beam Reinforcement Elevations
Wall Reinforcement Plans
Wall Reinforcement Elevations
Slab Reinforcement Plans
Data in the CSiXCAD BIM model is defined only once and any changes to a structural item in a drawing are reflected on all drawings where that item is shown.
CSiXCAD eliminates the need to manually transfer data and markups to CAD engineers and automatically generates an initial set of drawings that can then be customized and refined using CAD. When the engineer later makes changes to the original design model, CSiXCAD can compare the contents of its BIM model with the modified design model, and either import all changes or only selected changes. Previous edits made to the drawings in CSiXCAD are maintained, and a report listing the changes is generated.
[Image: homepage.png]
[-] The following 5 users Like temp1366's post:5 users Like temp1366's post
  • simanta, oanm2000, hamirjo, mowafi3m, taifur
  CSI CSiXCAD v21 poolmand 0 617 06-21-2026, 07:00 AM
  CSiXCAD v19 temp1366 5 7,645 05-15-2024, 07:02 AM
  CSiXCAD v20 Administrator 0 2,259 05-15-2024, 06:58 AM
Last Post: Administrator
