Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 12715:2000 Execution of special geotechnical work - Grouting
01-03-2011, 03:16 PM (This post was last modified: 01-03-2011, 07:09 PM by Grunf.)
Author: CEN/TC 288 | Size: 0.4 MB | Format: PDF | Publisher: CEN | Year: 2000 | pages: 56 | ISBN: 0580349330
[Image: 77937446822691181067.jpg]
This standard is applicable to the execution, testing and monitoring of geotechnical grouting work. Specific aspects concerning design are provided since ENV 1997-4 has been abandoned. Grouting for geotechnical purposes (geotechnical grouting) is a process in which the remote placement of a pumpable material in the ground is indirectly controlled by adjusting its rheological characteristics and by the manipulation of the placement parameters (pressure, volume and the flow rate). The following principles and methods of geotechnical grouting are covered by this standard : - displacement grouting (compaction grouting, hydraulic fracturing) ; - grouting without displacement of the host material (permeation, fissure grouting, bulk filling). Specialised grouting activities, generally associated with structural and/or emergency works, are not covered by this standard.
[-] The following 22 users Like ir_71's post:22 users Like ir_71's post
  â€¢ amrzaki200, vvvv, Grunf, ilgar, blaze, oanm2000, Dell_Brett, Adam Smith, utan, nhim4mat2006, salahcivil, usman, avge, roaming79, zrilek, tomcat007, jaejeong, uetian19, ykhackhack, Evandrojr, techno, tuanpecc1
06-02-2015, 04:27 AM
  â€¢ ykhackhack, zrilek, PinkPant, Dell_Brett, lisine, Jackass, Trishu999, Evandrojr, techno, uetian19, shadabg, malc, serhioSPA, utan
Threads: 57
06-29-2020, 02:52 AM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 4 users Like kowheng's post:4 users Like kowheng's post
  â€¢ shadabg, Dell_Brett, nhim4mat2006, oanm2000
 concreteok
E-Book Moderator
Malaysia
User ID: 4764
Threads: 38
Likes: 4,964 in 638 posts
Given Likes: 3501
06-29-2020, 04:12 AM
concrete solution advocate
[-] The following 11 users Like concreteok's post:11 users Like concreteok's post
  â€¢ hatkam, jcbv, babakfeyzi, PinkPant, cace-01, Dell_Brett, tuanpecc1, CAMSECT, avge, nhim4mat2006, oanm2000
  EN 14199:2005 Execution of special geotechnical works - Micropiles ir_71 4 6,395 03-03-2022, 08:55 AM
Last Post: concreteok
  EN 12716:2001 Execution of special geotechnical works - Jet grouting ir_71 4 5,757 06-29-2020, 02:54 AM
  EN 15237:2007 Execution of special geotechnical works - Vertical drainage ir_71 1 2,825 11-03-2012, 04:44 PM
Last Post: st77bel
  EN 14475:2006 Execution of special geotechnical works - Reinforced fill ir_71 1 2,976 10-27-2012, 07:55 AM
Last Post: st77bel
  EN 12699:2000 Execution of special geotechnical work - Displacement piles ir_71 4 4,687 09-20-2012, 03:48 PM
Last Post: 3fan
