Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 369.1: Seismic Evaluation and Retrofit of Existing Concrete Building
 agelos100
Member
User ID: 34967
Threads: 12
Likes: 173 in 18 posts
Given Likes: 378
06-08-2020, 07:17 AM (This post was last modified: 02-27-2023, 08:09 AM by Administrator.)
ACI 369.1M-17 Standard Requirements for Seismic Evaluation and Retrofit of Existing Concrete Buildings
[Image: 89452121104133321828.png]
  • Author(s): ACI Committee 369
  • Published By: ACI
  • Size: 2.186 MB
  • Quality: Original Preprint
[-] The following 18 users Like agelos100's post:18 users Like agelos100's post
  β€’ Batman07, blaze, pedzaquino, Dell_Brett, cace-01, subin91, babakfeyzi, jcbv, mgdario, promo8, zrilek, solon, oanm2000, spat, bigone, apocalipse, simanta, gulilero
 Veggeta
Guatemala
User ID: 114
Threads: 98
Likes: 4,273 in 520 posts
Given Likes: 403
06-08-2020, 07:14 PM
[-] The following 6 users Like Veggeta's post:6 users Like Veggeta's post
  β€’ PinkPant, malc, Dell_Brett, oanm2000, bigone, spat
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
06-12-2020, 10:38 AM
[-] The following 7 users Like bigone's post:7 users Like bigone's post
  β€’ Dell_Brett, oanm2000, kowheng, PinkPant, jokerβ„’, Umer.Aleem, nhim4mat2006
Likes: 8,311 in 1,373 posts
Given Likes: 94
02-27-2023, 07:54 AM
ACI CODE-369.1-22: Seismic Evaluation and Retrofit of Existing Concrete Buildingsβ€”Code and Commentary
Author(s)/Editor(s): ACI Committee 369| Format: PDF| Year: 2023| pages: 125 | ISBN: 9781641952040
[Image: 85108201363841790128.png]
This code provides retrofit and rehabilitation criteria for reinforced concrete buildings based on results from the most recent research on the seismic performance of existing concrete buildings. The intent of this code is to provide provisions related to concrete material and concrete members, including material testing criteria, modeling parameters, and acceptance criteria for use within the ASCE 41 framework, similar to how the National Earthquake Hazards Reduction Program (NEHRP) Recommended Seismic Provisions produced by the Federal Emergency Management Agency (FEMA) (FEMA 450) have served as source documents for the International Building Code (IBC) and its predecessor building codes. Starting in the 2023 edition, ASCE 41 references ACI 369.1 directly for concrete-related provisions. Chapter and section numbers of ASCE 41 cited in ACI 369.1 correspond to ASCE 41-17 unless otherwise noted.
This code should be used in conjunction with Chapters 1 through 8 of ASCE 41-17 and applicable sections of the ACI 318-19 Building Code. Chapter 1 of ASCE 41 provides general requirements for evaluation and retrofit, including the selection of performance objectives and retrofit strategies. Chapter 2 of ASCE 41 defines performance objectives and seismic hazards. Chapter 3 of ASCE 41 provides requirements for evaluation and retrofit, including treating as-built information and selecting appropriate screening procedures. Chapter 4 of ASCE 41 summarizes Tier 1 screening procedures, while Chapters 5 and 6 summarize Tier 2 deficiency-based procedures and Tier 3 systematic procedures for evaluation and retrofit, respectively. Chapter 7 of ASCE 41 details analysis procedures referenced in ACI 369.1, including linear and nonlinear analysis procedures, acceptance criteria, and alternative methods for determining modeling parameters and acceptance criteria. Chapter 8 of ASCE 41 provides geotechnical engineering provisions for building foundations and assessment of seismic-geologic site hazards. References to these chapters can be found throughout the standard. The design professional is referred to FEMA 547 for detailed information on seismic rehabilitation measures for concrete buildings. Repair techniques for earthquake-damaged concrete components are not included in ACI 369.1. The licensed design professional is referred to ACI 562, FEMA 306, FEMA 307, and FEMA 308 for information on evaluation and repair of damaged concrete wall components.
This code does not provide modeling procedures, acceptance criteria, or rehabilitation measures for concrete-encased steel composite components.
acceptance criteria; building; deformation-controlled; dynamic analysis; earthquake; force-controlled; modeling parameters; nonlinear analysis; retrofit; seismic evaluation, seismic assessment; structural evaluation.
[-] The following 14 users Like poolmand's post:14 users Like poolmand's post
  β€’ Dell_Brett, blaze, TAFATNEB, subin91, PinkPant, cheosmith, babakfeyzi, temp1366, mgdario, zrilek, milova, daywalker, kowheng, cace-01
Given Likes: 94
11-05-2023, 07:05 AM
Author(s)/Editor(s): ACI Committee 369 | Size: 70.1 MB| Format: PDF| Quality: Scanner| Year: 2023| pages: 125
[Image: 08787112155268702119.jpg]
  β€’ jcbv, PinkPant, babakfeyzi, kowheng, Umer.Aleem, temp1366
  [CivilEA Exclusive] ACI SP-364: Serviceability and Performance Evaluation of Concrete Bridges and Structu poolmand 0 2,699 04-19-2025, 12:42 PM
  [CivilEA Exclusive] ACI ITG-11: Statistical Techniques for Assessment of Existing Concrete Structure poolmand 1 3,274 12-15-2024, 06:59 AM
  ACI E702.8: Designing Concrete Structures: Evaluation of Concrete Cores Test Results poolmand 0 1,544 08-28-2024, 06:12 AM
  [CivilEA Exclusive] ACI 364.7: Evaluation and Minimization of Bruising in Concrete Repair poolmand 0 1,822 11-05-2023, 06:59 AM
  [CivilEA Exclusive] ACI 364.2: Increasing Shear Capacity within Existing Reinforced Concrete Structures poolmand 0 1,735 11-05-2023, 06:37 AM
  ACI 369: Guide for Seismic Rehabilitation of Existing Concrete Frame Buildings and ir_71 3 3,740 05-09-2023, 10:29 AM
  ACI 562: Code Requirements for Evaluation, Repair, and Rehabilitation of Concrete junaid 8 5,518 05-06-2023, 10:45 AM
